Front anti roll bar brackets and clamps £20
New powerfelx rear roll bar bushes £25
Powdercoated front roll bar brackets £30
Powder coated roll bar smaller than 24mm £15
2 standard turbos with manifolds slight play £60, spares one £30
Standard manifold £20
standard clocks £35 started to peel by speedo
standard erst cam £30
new lifters/trappets £30
dash computer £25
centre gauge mount with racetech volts gauge £50
Hi Bro, Your new "standard" lifters ???? Still got them if so ill have them please??? dont suppose you have new followers also. Also after a big front mount to>??? Many thanks mate Chris
It's adjustable on the threads Aston.....has a nut each side rather than a physical stop! That way it can be moved forward or backwards by adjusting the nuts thus changing the geometry of the setup!
thanks forthat . made by firstline . I don't need then aby more
