Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
blower motor resistor
Old Dec 22, 2012 | 06:33 PM
riskman2012's Avatar
riskman2012
Default blower motor resistor
please could someone tell be how I find the locationof the blower motor resistor in my ford focus 2003 thanks
Old Dec 22, 2012 | 06:45 PM
martysmartie's Avatar
martysmartie
Yes it's to the right of the glovebox when you drop it down, you do however need to fix the immediate problem that causes the resistor pack to go, this is normally due to badly fitted pollen filters!
Martin
Old Dec 22, 2012 | 07:24 PM
cabriolet's Avatar
cabriolet
and the melted wiring plug
Old Dec 23, 2012 | 12:51 PM
riskman2012
is the melted wiring plug separate from the blower resistor ??
Old Dec 23, 2012 | 01:07 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Yes, pollen filter scuttle not sealing is the issue, part number for resistor is 1311115 and is just over 14 quid plus vat, ask for butl tape when you visit your local ford dealer
Old Dec 23, 2012 | 01:28 PM
riskman2012
thanks I have ordered a resistor do I need a pollen filter shuttle too and if so where is this located if you could please tell me
Old Dec 23, 2012 | 01:39 PM
Ginge !'s Avatar
Ginge !
Passenger side bottom of windscreen
, take out glove box to access the resistor,,, that's on passenger side middle of dash
Old Dec 23, 2012 | 04:06 PM
COLEYST200's Avatar
COLEYST200
Old Dec 23, 2012 | 04:07 PM
riskman2012
Thanks very much
Old Dec 23, 2012 | 04:15 PM
Ginge !'s Avatar
Ginge !
Bit extreme taking out windscreen for pollen filter change lol
Old Dec 29, 2012 | 11:00 AM
riskman2012
Default blower resistor motor
how do I remove the glove box please sorry to be a numpty
Old Dec 29, 2012 | 09:35 PM
martysmartie
I have answered your PM, but anyway, you squeeze the two sides in, so that the 'stops' which usually prevent it from dropping down clear the dash, this may give you enough room to work, but otherwise it's just a case of unscrewing it/unbolting it from there.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
bobsworth
77
Mar 24, 2016 09:30 PM
beller
Sep 21, 2015 04:13 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
marky_g
Sep 12, 2015 04:26 PM
