New Member with a problem
Old Dec 21, 2012 | 10:32 AM
James_PSL's Avatar
James_PSL
Default New Member with a problem
Firstly Hi,
Right I have a ST170 was driving home last night when the EML came on just as i pulled into the drive, I am used to this however as the car has a full exhaust system on it and no CAT.
Plugged my scanner in expecting it to be about a lambda sensor like normal but no a P1581 came bk unknown fault so googled the code somthing to do with a electronic throttle or something but when i looked under the bonnet my throttle is a cable.
So any help would be greatly appreciated
Thanks James
Old Dec 21, 2012 | 12:20 PM
chalkey's Avatar
chalkey
rst junkie
my dad had the same problem with his, i tried many times to fix it, there is a secondary airflap control type thing that fails on them, its about £200 from ford for the part
Old Dec 22, 2012 | 01:40 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
inlet manifold runner control (imrc). dont buy a new one until you google the fixes for it first. will save you 200. think the spring fix is on focus fanatics. try a search
Old Dec 22, 2012 | 01:44 PM
The Underdog
you cant fix stupid
here you go
http://fordfocusworld.com/forums/vie...php?f=25&t=577
Old Dec 23, 2012 | 07:16 PM
James_PSL's Avatar
James_PSL
Originally Posted by Underdog ST170
Thanks for the info
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Flateric_2002
Sep 15, 2015 08:41 AM
