can a 2wd L6 ecu be replaced with a 4X4 L8 ??????????
Old Mar 9, 2005 | 11:13 PM
gavintwopies's Avatar
gavintwopies
Default can a 2wd L6 ecu be replaced with a 4X4 L8 ??????????
As above i've been asked by a friend to ask you people in the cossie world if you could answer a simple enough question :
My friend has a 1990 H reg 2wd cossie apparently fitted with a L6 ecu......?
the question is his car is std bar the scorpion and K and N Filter but he has been offerd the full stage 2 kit of a J reg 4X4 believed to be a L8 ecu (stg 2) along with a 3 Bar, 803's and -31 the question is can he simply plug and play or are the 2 types just not compatible??????? so he will need to go looking for a stg 2 L6 or a stg2 2wd ecu???
many thanks
MR,2,PIES
Old Mar 10, 2005 | 07:04 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yes a 1990 2wd will have a L6 as standard.
yes that's possible, but he'll also need a 4x4 TPS known as a PF09 (also used on some cars from the Fix It Again Tony group), and you'll need to swop the outer 2 wires on the tps sensor connector around as the PF01 and PF09 work the other way around.
get the fuelling checked afterwards as well.
CosKev3's Avatar
CosKev3
Will swap over easy enough m8
Will need 4x4 throttle position sensor,and then swap the outer wires on the wiring plug for throttle position sensor
CosKev3's Avatar
CosKev3
Bollox!!!!!!Beat to it
Old Mar 10, 2005 | 06:16 PM
gavintwopies
Good stuff people however if i have both of these tps in my hand how obvious are the differences between the 2 or is it just down to the ford pt. no. on the side, if so would you happen to know these off hand...........
the thing is i know for a fact that i'm going to get lumped with the graft of having to put all the bits on the car and all the wire swapping etc........
rs turbos are so much easier than all this webber marelli stuff
(however there shit slow by comparison)
Old Mar 10, 2005 | 10:56 PM
boon's Avatar
boon
The 4x4 definately has PF09 stamped on it - I think the 2wd will have PF01 (not sure about the PF02 in previous post - perhaps Big Fin and 2wd Saph were different too?)
Old Mar 11, 2005 | 11:00 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i've edited my reply now, the 2wd should be pfo1
Old Mar 12, 2005 | 10:42 AM
gavintwopies
Cheers for that ppl we now have hold of a full 4x4 throttle body inc. iscv and pfo9 for 60 notes!!!!!!!
was i ripped or is that ok????
big_Rad
Sep 15, 2017 09:36 AM
FlashRS
Sep 14, 2015 12:36 PM
FlashRS
13
Aug 31, 2015 06:02 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Old ford
Jul 31, 2015 06:50 AM
