Ford Range This section is for other models in the Ford range.
06 transit connect thermostat help
Old Dec 13, 2012 | 10:22 PM
samsamz's Avatar
samsamz
Default 06 transit connect thermostat help
Right I bought a 06 transit connect yesterday an the hour drive back from bristol the heaters didn't heat up at all so I reckon its thermostat my question is without looking at the engine where abouts is the thermostat on these an what tools will I need
Is it a bastard job todo or an easy one?
Thanks sam
Old Dec 14, 2012 | 07:25 PM
Remove the intercooler and you will see it.Its only a few bolts that hold the stat in.There is a pipe that goes to the stat housing and goes to the header tank.Sometimes this gets blocked up.
Old Dec 15, 2012 | 09:05 AM
samsamz's Avatar
samsamz
Thanks glenn will check the pipe too
Old Dec 15, 2012 | 09:23 AM
RichieST's Avatar
RichieST
Put a thermostat on my old connect work van was a very easy job. Put a container under the housing to collect any coolant you may loose then just pour it back in the top again!
Old Dec 15, 2012 | 09:27 AM
Sticky.'s Avatar
Sticky.
Mine, did that...took me ages to find out the pipe had blocked.
Old Dec 15, 2012 | 09:44 AM
samsamz's Avatar
samsamz
What does the pipe block up with? Where abouts does it usually block?
Old Dec 15, 2012 | 09:46 AM
samsamz's Avatar
samsamz
I'm gonna flush the system anyway cus the guy I had it off didn't look after it tbh but can't complain only paid £900 for it
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
stevecfrst1
Sep 30, 2015 05:18 AM
The Enigma
Sep 29, 2015 10:31 AM
