Ford KA Discuss your Ford KA here!
KA on Carbs
Old Dec 13, 2012 | 06:35 PM
Dan_c's Avatar
Dan_c
Default KA on Carbs
hi all has any1 put a KA on carbs?
i obviously im rebuilding the engine for this rally car, but, i was thinking is the easiest way around this to put an escort/kent engine in as i would then have a dizzy?? looking at the price of these carb kits with management this would appear the cheapest way.
i know the engine looks the same but are the mountin bolts the same??
cheers
Old Dec 13, 2012 | 08:22 PM
daz1968's Avatar
daz1968
I would have thought as long as engine is pre 1992 and you can prove it then shouldn't be a problem as then mot won't require a cat and carbs will be good enough. Not sure about block being same but pretty sure it can be made to fit.
Old Dec 13, 2012 | 10:05 PM
Dan_c's Avatar
Dan_c
Mot won't be a problem, even I'd I stick with the existing engine I would get rid of the cat for a bit more power. The block looks he same, it can't be a million miles away can it, I think it would run better with a weber on it anyway
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
sridgett
13
Sep 27, 2015 06:03 PM
