Ford KA Discuss your Ford KA here!
misfire problem
Old Dec 10, 2012 | 11:09 AM
mariag's Avatar
mariag
Default misfire problem
Hi
Have a ford KA 2004 and it has a misfire problem, we have changed the coil, leads and spark plugs, fuel filter, oil filter and air filter. Exhause appears ok, anybody got any other suggestions
Old Dec 10, 2012 | 11:24 AM
RichieST's Avatar
RichieST
When does it misfire? All the time or just under load etc?
Do you know which cylinder it is? Take each lead off in turn and when the misfire doesn't get worse that'll be the cylinder. Check the plug to see if it's wet with fuel. If it is then I'd be doing a compression test, if not then i'd be looking at an injector / ECU issue.
Old Dec 10, 2012 | 11:34 AM
mariag's Avatar
mariag
its mainly in higher gears feels like i am constantly driving in a lower gear
sorry i'm not being very helpful am I
carl n 1977's Avatar
carl n 1977
try another coil pack had this my self at work was a cheap coil pack
Old Feb 18, 2013 | 03:16 PM
pinkrst's Avatar
pinkrst
not sure if u mite have the same problem, but I have just bought a sport ka, misfire the way u are describing, and turns out its an injector...quite common on the sport ka 1.6 from what I have experienced.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
