Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
mk1 focus rs cutting out
Old Dec 8, 2012 | 06:52 PM
Smithy23's Avatar
Smithy23
Default mk1 focus rs cutting out
I have a problem with cutting out on my focus it's been doing it for the last 3weeks now. and it's getting to me
it's cutting out when I put my clutch in. when driving coming up to junctions also when clutch is pressed when rolling .
it don't cut out when I'm just sat there idling.
I didn't have the problem before I bluefined it.
I have tried to learn it how to idle again by loading car up things like that also disconnected battery for a night. changed battery and also changed idle control valve.
and looked for boost leaks
what's next.... need idea's please
Old Dec 8, 2012 | 07:16 PM
RichieST's Avatar
RichieST
Has it got a dump valve? They can cause all sorts of running issues.
Old Dec 8, 2012 | 07:24 PM
Smithy23's Avatar
Smithy23
Ye I heard that to ill block it off tomorrow and see if it helps. I have replaced maf too. But was second hand. All started after plugging in and uploading a bluefin
Old Jan 9, 2013 | 02:52 PM
Ali_B's Avatar
Ali_B
could be you Idle Control Valve, was when mine was doing this, pulling up to junctions ect and just wouldnt idle, took the ICV and throttle body off cleaned them up, and was good as new.
pretty common i think.
Old Jan 9, 2013 | 07:06 PM
Smithy23's Avatar
Smithy23
I have changed icv for new the coilpack now the car has stopped cutting out but still drops revs when coming to a stop sits at like 650rpm then revs back up to normal after few secounds
Old Jan 9, 2013 | 07:11 PM
adsrs1's Avatar
adsrs1
I would try an ecu reset then start the car with the fans and lights on for ten mins ticking over then take it for a 20min drive so it can re learn its settings
Old Jan 9, 2013 | 11:00 PM
Smithy23's Avatar
Smithy23
ye done that to fix it a few times
Old Feb 7, 2013 | 07:19 PM
ian_zs's Avatar
ian_zs
Are you running a standard re circulation type dump valve or an aftermarket atmospheric one?
Mine used to do the same with a bailey DV26 fitted so changed to a forge re circ and solved it
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
Ben26
Sep 3, 2015 07:55 PM
Sep 3, 2015 10:49 AM
