Sierra diff
Old Dec 6, 2012 | 08:57 PM
orion turbo's Avatar
orion turbo
Default Sierra diff
Trying to figure out my sierra diff. I've worked out its 7.5 in and a 3.92 but can't figure the little plate to see if its an LSD or not. Don't really want to take cover off.
When I have the car jacked up so both rear wheels are off the ground. If I turn one of the wheels the other one turns as well.
What does that indicate?
Old Dec 6, 2012 | 09:42 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
have 1 wheel off the ground and try to turn the nose drive or the opposite drive flange
Old Dec 6, 2012 | 09:51 PM
orion turbo
So have one wheel off the ground and try to turn it?
Old Dec 6, 2012 | 10:06 PM
martysmartie's Avatar
martysmartie
You have an LSD, if the opposing wheel spins in the same direction.
Martin
Old Dec 6, 2012 | 10:07 PM
Cossie Sean
yes, with the car in gear not running
if it is an LSD the wheel will be very tight to turn, if you can turn it!
same check with a diff on the floor,
hold one drive flange so it wont turn, turn the nose drive and if you struggle to hold the drive flange still, its LSD, if the opposite output flange turns freely while nose drive is turned, its and open diff
Old Dec 6, 2012 | 10:09 PM
Cossie Sean
not always the case, it must "turn the same way" when forced under load
lots of vehicles when both wheels are jacked up will turn both wheels in same direction, with no LSD
this must always be checked under specific conditions, incase of badly worn LSD`s or tight open diffs
Old Dec 8, 2012 | 12:07 PM
orion turbo
With one wheel on the ground and car in gear it's near impossible turn the lifted wheel. What's that mean then.
Old Dec 8, 2012 | 01:10 PM
dojj's Avatar
dojj
Resident Wrestling Legend
It will be because you are trying to turn the wheel, which is connected to the diff, which is trying to turn the other wheel, which is on he ground, so then it will try to turn the prop, which will try to turn the gearbox output shaft, which is geared to the main shaft, which is connected to the input shaft, which is held in place by the clutch, which is connected to the engine
So you can move the wheel to take up all the slack until you are then trying to turn the engine with that wheel
If you are not in gear the output shaft is not locked to the countershaft in the box so both will rotate freely and let you turn the wheel
Old Sep 1, 2016 | 08:25 PM
kosi's Avatar
kosi
Default sierra diff seems stuck
Hi
I recently took my diff out and replaced radial drive shaft seals
to do this i sat it on its side and knocked the seal in - both sides
now when i try and turn it by hand it turns then seems to jam ?? turn it back and rotates but then also jams later ?
could i have knocked something loose ?
thanks
chowfornow
14
Jan 5, 2019 09:01 PM
muzzman1
Sep 30, 2015 08:59 PM
mark r
Sep 29, 2015 07:27 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
