COMPBRAKE Master cylinders, experiances?
It would be safer using a water pistol as a cylinder!
They are shocking!
I changed mine to genuine Girling ones from Burton when I had the Lego edition OBP pedal box....
Now run with the Tilton cylinders and Tilton pedal box.
They are shocking!
Pm me if ya want love
No worries mate, I went for the overhung Tilton box in the end.
Took a bit of fabricating to get it in but it's AMAZING now.
The difference is out of this world and all down to a properly designed pedal box with ratios and balance bar that actually work.
Speak to these guys great advice and always happy to help.
http://www.competitionsupplies.com/
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
I agree
aka Turbosailorboy
comp brake cylinders are total crap just like there pedal box,s all three cylinders leaked & the pedal ratio was so bad i could not lock up the wheels even when i tried too.
AP cylinders all the way for me now with Tilton pedal box same as Luca,s
compbrake products are very good fantastic value for money product
if you have any problems with items just ring them and they will help
thats from working with there products for over 5 years
Igot compbrake
top mounts which are good quality for the money
adjustable tca,s
compression struts
the bolts sheared on both comp struts holding them to the tca,s
bias pedal box which all 3 cylinders leaked
i was supplied zinc plated bolts instead of black self colour bolts its the only thing i can think of why they snapped .
fortunately i was pulling my car out of the garage so very slow.
