Project #2 - Mk1 Fiesta ( long term restoration )
Old Nov 30, 2012 | 04:55 PM
Adz82's Avatar
Adz82
project rat
Wink Project #2 - Mk1 Fiesta ( long term restoration )
Gonna be a long 1
Picking up this weekend 01/12/12 - 02/12/12
Will then put more picy's up
Old Nov 30, 2012 | 05:29 PM
NobbyClark's Avatar
NobbyClark
Fantastic. Im looking forward to this!
What are your plans for the fezzie?
Old Nov 30, 2012 | 05:59 PM
Adz82's Avatar
Adz82
project rat
Well my current 1 is original & only has 2 bad bit's of patch up welding done on the driver's side & 1 grotty bit on the passenger side rear arch...
My plan's for that on the outside now is to leave it in red primer & tidy the inside & hopefully get a turbo on the little 957cc for something different Crossflow version of the "eccoboost" pmsl
As for this 1 the shell is all original & totally mint with no rust or rot
It's coming with everything to put it back on the road
It should be a 1.1 but I think I'm gonna go 1.6 crossflow & make it into a XR2
The hardest bit's to get hold of will be interior
This will be a long term build & I don't think I'll do anything till early next year.
The main thing i want to do is get dry stored & waxed over winter so the rust doesn't get to it
Old Nov 30, 2012 | 09:36 PM
Will keep an eye on this.
Old Dec 1, 2012 | 05:54 PM
Adz82's Avatar
Adz82
project rat
Got it back today & there is a hole I punched through in the normal place by the rear washer bottle
Found a bit at the lower part on 1 of the front wing's & the head light fixing's area need's attention
Not as good as I had been told but all an easy fix
So that's on the drive with the other 1
Also had a RESULT whilst I was there...
Buying yet another off the same lad as It's had a minor front end so will be using that for part's & breaking it
Got the pair for Ł500's
Pick the other 1 up in the new year
Old Dec 2, 2012 | 04:08 PM
Adz82's Avatar
Adz82
project rat
1300gt
Sep 7, 2015 12:06 PM
Toe Knee
Aug 23, 2015 08:31 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
