Turbo bearing play
Old Nov 30, 2012 | 08:30 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Default Turbo bearing play
Is it side to side movement or in and out that's the main problem?
Also, where can I get an adapter plate for an RST manifold to fit a zetec?
Old Nov 30, 2012 | 08:35 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
in and out on a normal journal bearing turbo isn't a good thing.
gt's vary a little as they have in and out play to use for oil cushioning apparently.
Old Nov 30, 2012 | 08:44 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Thanks mate.
It's just a standard RST T3, I was told it had some play but I'm struggling to feel any in-out, just a little side to side.
Old Nov 30, 2012 | 08:49 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
side to side is ok, that is usually taken up when oil gets round the journals.
as long as the blades don't contact the housings when running it should be fine.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
Danielbetty
Aug 23, 2015 12:52 PM
druidgetafix
Aug 15, 2015 10:22 AM
