Ford Range This section is for other models in the Ford range.
Leaking boot on Orion
Old Nov 28, 2012 | 02:40 PM
orion james's Avatar
orion james
sump smasher :)
Lightbulb Leaking boot on Orion
Hi all I was just wondering if the boot leaking on mk2 orions is a common fault as I can't work out how the water is getting in, the rubbers are in good nick so it's left me a little confused
Hope somone has some idea's cheers James
Old Nov 28, 2012 | 02:47 PM
STeve's Avatar
Super Moderator
fold down rear seats lay in the boot with a torch and get someone to turn the hose on if not raining, I had one years back that leaked through rear lights and bootlid did not depress enough to make a good seal on rubber
Old Nov 28, 2012 | 02:52 PM
orion james
sump smasher :)
Oh top man cheers for the reply mate ill give that ago
Old Nov 28, 2012 | 05:21 PM
slammedorion's Avatar
slammedorion
Back light seals, split or blocked sunroof drain tubes.
Get on the Orion register if you get stuck.
Old Nov 28, 2012 | 06:10 PM
primedog's Avatar
primedog
also if any signs of rot at lower corners of rear screen gulley. mine had a little lookin rusty bit, wen i got it stripped back it was massive n the water used to run down soaking thru the rust into the boot.
Old Nov 28, 2012 | 09:55 PM
orion james
sump smasher :)
Cheers guys ill take a proper look tommorow and see if I can sort the proplem and ill sign up to the Orion register soon as pal gotta pass my test first lol thanks for your help
Old Nov 29, 2012 | 06:39 PM
costina's Avatar
costina
Live long and prosper!!
I would go for screen too had one years ago which had a replacement screen which leaked and rotted all the inner arch by fuel cap.
boeb
Jan 9, 2020 05:11 AM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Fudgey
21
Sep 30, 2015 06:19 PM
