T61 turbo, tube maifold, ext wastegate
Hi all, parts recently removed from a 4x4 saph, downgrading spec,all in working order, what you see is what you get!!
Turbonetics T61 Turbo,T-11859, small amount in/out play on it, otherwise seems fine, Tube manifold with external waste gate, which is linked into a 4x4 downpipe.
Swedish style plenium, uses standard tumpet side, with dellorato throttle body and TPS, [ T/body inlet measures 72mm id]
£1100 for the lot.
£1100 for the lot.
JK12
33
Apr 26, 2021 12:09 PM
