cvh turbo engine block and other engine parts
Old Nov 23, 2012 | 10:44 PM
studabear's Avatar
studabear
Default cvh turbo engine block and other engine parts
I have a decent cvh turbo engine block, removed from my cabrio a year or so ago, held coolant perfectly, has the cps hole in it so is good for efi.
Looking for £50 collected or you can arrange your own courier.
Will throw in a crank and any other bottom end parts you might want.
Also have a rs turbo head with a piper 285t camshaft, I havn't heard this run, but can check the condition of camshaft and lifters and can keep lifters in the correct order etc.
£50 owns it, collected or sort your own courier.
My stage 2 T3 might be up for grabs soon too, cost me near £600 from cr turbo's around 2 years ago, done approx 2k, need to check condition and if any play etc before giving a price, also should have receipt too
Complete cvh turbo engine, bit of a rattler, sump gasket leaks a bit and oil light flickers a bit at idle when proper hot, cam and followers etc are in good order, water pump and cambelt recent, can be hear running or even taken for a drive if before end of the month.
Ideal for a stop gap or a rebuild while you keep your engine fitted, pulls really well, only removing as going full zetec route.
£100 for the engine with no manifolds etc.
Also have a ferriday efi adapter plate to fit efi inlet to mfi head, the ferriday adapter looks far superior to any other adapter plate I've seen ANYWHERE, cost me over £100,
I want £60 delivered to your door.
I've got quite a few other parts knocking about, so If you need something give me a shout I might be able to help
Stu
Old Nov 23, 2012 | 10:48 PM
davidfordrs's Avatar
davidfordrs
Default Water pipe
hi mate I need the water coolant pipe that bolts to the top of the turbocharger if you have one cheers.
Old Nov 23, 2012 | 10:56 PM
studabear's Avatar
studabear
Sorry bud, I run a s1 oil cooled turbo.
Old Nov 24, 2012 | 09:17 PM
drewfordz's Avatar
drewfordz
hey fella does that block have pistons with by any chance cheers
Old Nov 24, 2012 | 10:06 PM
studabear's Avatar
studabear
it can have need to have a look at them to see what condition they are.
Old Nov 26, 2012 | 12:43 AM
tejy's Avatar
tejy
Hi mate can you get a pic up of the ferriday efi adapter plate please.
Old Nov 26, 2012 | 05:24 PM
studabear's Avatar
studabear
yeah no problem, I've just removed it today as I've sold the inlet set up.
Its not quite as shiny but all the old gasket is removed.
Old Nov 26, 2012 | 05:36 PM
liam-rst's Avatar
liam-rst
shit happens
Is the efi block still available? If so is there any lipping to the bores and are they standard size?
Old Nov 26, 2012 | 05:41 PM
zxevhbonus's Avatar
zxevhbonus
old school
Hi have you come up with a price for the turbo and where abouts
In the uk are you
Thanks
Old Nov 26, 2012 | 05:48 PM
studabear's Avatar
studabear
Yes still available, no lipping that I can remember, can double check for sure. bores were standard sized, nothing stamped on pistons like +0.5 etc
Stu
Old Nov 26, 2012 | 05:50 PM
liam-rst's Avatar
liam-rst
shit happens
if you could double check on the popping id be very interested mate,
Where abouts are you?
Old Nov 26, 2012 | 07:49 PM
studabear's Avatar
studabear
I've had a look and it looks fine, but this was using a inspection lamp with the engine at the bottom of my shed in the dark, to be 100% sure I aint gonna be able to look at it in daylight till sunday.
Located in blackpool lancs
Old Nov 30, 2012 | 05:31 PM
studabear's Avatar
studabear
adapter plate sold
Old Dec 2, 2012 | 09:58 PM
studabear's Avatar
studabear
head, and block sold pending payment/collection
Old Dec 9, 2012 | 05:09 PM
studabear's Avatar
studabear
Bump, for the weekend, only thing left at the minute is the complete engine.
Old Jan 11, 2013 | 09:22 PM
JasonXR2Racer's Avatar
JasonXR2Racer
have you got an EFi flywheel at all?
Old Jan 17, 2013 | 06:44 PM
XR2.ZVH's Avatar
XR2.ZVH
Where abouts are u located m8 and is the engine efi or mfi? Cheers
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
Old ford
Jul 31, 2015 06:50 AM
