Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
when i hit the brakes idle goed down
Old Nov 23, 2012 | 01:06 PM
bercea2001's Avatar
bercea2001
Exclamation when i hit the brakes idle goed down
Hi
I have a FOCUS 2001 1.6 - 16v, for a while when i hit the brakes in stop position the idle speed goes down. You have any hint in this matter.
Best regards
Old Nov 23, 2012 | 01:11 PM
pani_k's Avatar
pani_k
PassionFORD Member
If when coming down to idle this happens, remove, clean and lubricate the idle speed control valve, located underneath the inlet manifold.
Old Nov 23, 2012 | 01:41 PM
bercea2001's Avatar
bercea2001
I cleaned the idle speed control valve with carburetor cleaner, but i did not lubricate it. you think this is tre problem?
Old Nov 23, 2012 | 02:36 PM
bercea2001's Avatar
bercea2001
in this movie i was stopped at the red light and i hit the brakes two timies.
Old Nov 23, 2012 | 02:43 PM
pani_k's Avatar
pani_k
PassionFORD Member
The brake servo takes a vacuum from the inlet manifold so you may have a leak hence why when you push the brakes it starts vibrating.
SmudgerByName
52
Jul 28, 2016 06:14 PM
muffster
13
Sep 3, 2015 09:40 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
