Yb cylinder head experts
Old Nov 22, 2012 | 08:00 AM
SaphCos4x4_Dan's Avatar
SaphCos4x4_Dan
loves a good ham shank
Default Yb cylinder head experts
What's the minimum head thickness that can be used? How do I tell the difference between a 2wd and 4wd head? Are there any cr differences between the two (I'm using a 200 block)? And how do I choose pistons and rods to get the right cr (I'm after long rods and short pistons)?
Dan
Old Nov 22, 2012 | 10:16 AM
The Youth.'s Avatar
The Youth.
138.68 min according to the book(but lots are below this)
2 wd has a bracket/casting above the exhaust ports for a turbo hanger and the coolent temp sensor for the dash is at the front next to this (on a 4x4 its at the back near the ecu temp sensor (the blue one))
the 4x4 has a slightly less cr than the 2wd
the heads are interchangeable without touching the bottom end
spacers are req if fitting 4x4 cams in a 2wd head
steve
Old Nov 22, 2012 | 11:49 AM
SaphCos4x4_Dan
Thanks Steve much appreciated
Would a 138.3 head be scrap or still useable if it was freshly skimmed to this thickness?
Old Nov 22, 2012 | 11:54 AM
The Youth.'s Avatar
The Youth.
I believe there are heads fitted that are 137.XX
the issue when over skimmed is the exhaust seat falling out, the area around there is extremely thin when overskimmed
it's a case of take your chance..
steve
Old Nov 22, 2012 | 12:16 PM
martysmartie's Avatar
martysmartie
The minimum thickness is 138.x MM (can't remember the last figure), if you head over to the "Tech essay" room, there is a article by Stu, as to why this is.
The reason is when they are skimmed below this, you start loosing material around the valve seats.
Martin
Old Nov 22, 2012 | 08:09 PM
costina's Avatar
costina
Live long and prosper!!
138.68mm
Old Nov 22, 2012 | 08:16 PM
botters's Avatar
botters
competant bodger
you can have stakes put in the valve seats to make them usable below 138mm
Old Nov 22, 2012 | 08:28 PM
B18PWR's Avatar
B18PWR
The problem is the piston to valve clearence with std crown heights, at 138 you are way off the valve seats falling out .
Nov 1, 2015 06:53 PM
DavidK
Sep 27, 2015 02:55 PM
