2007 Focus ST Clutch Vibrating
Hey guys first post
Jim from Galway in ROI here, anyways my clutch pedal has started vibrating like mad on my Pre facelift ST and im pretty sure it's the flywheel.
Gearchange isn't the same and car feels pretty sluggish on power and gearchanges. I have read solid flywheels are an option but i have also heard that MK2 ST/RS don't have the damper springs as standard as this to protect the gearbox so im stumped.
Will be bringing it to my mechanic tomorrow for a look and was wondering how much roughly a replacement dual mass flywheel kit is and if it's ok to drive the car with the DMF on the way out.
Thanks, looking forward to my time here
Good luck with the fix, I've heard different stories regarding converting to a solid flywheel so it's all about what you want or probably more to the point what you can afford !
I would try to avoid driving it as if the flywheel starts breaking up bits can fall into and potentially ruin the starter motor !
Know anywhere that does a good price on RS clutch kit ? Not many performance specialists in the ROI although i do have a local Indy who is great. Im loathe to get flywheel replaced and paying for all the labour involved w/o atleast getting an important mod out of the way
Pumabuild doing them delivered for 620 sterling+27 pound postage to ROI, will just have to make sure all the ancillaries come with that before i go to my mechanic tomorrow
Thanks alot guys
Thanks alot guys
Financially i will probably have to still use car for a week and a half or so until i get the money together to get it bought and fitted and that would be my main concern. Thanks alot for thinking of me though
No worries mate. I got mine through these http://www.part-box.co.uk/ genuine ford parts and very helpful. Blokes called Paul Dolan. He will sort you out.
I then had them fitted at a local garage who have me my old clutch kit back as it was in good nick.
http://www.jam-sport.co.uk/home/ford...-on-st225.html
Jam sport doing it too but w/o release plate it seems, hmm will look those guys up thanks, if this is 100% the problem i need to buy the parts quick as RS clutch kit prices are going up
NC53
Sep 13, 2015 03:05 PM
