Best Turbo Air Filter
Old Nov 19, 2012 | 09:44 AM
surrey_100e's Avatar
surrey_100e
Default Best Turbo Air Filter
Can anyone recommend a good air filter for my turbo? Ive read that the oil impregnated cotton air filter can cause damage? Theres so many different types i dont know what one i need.
Any advice would be great.
Old Nov 19, 2012 | 09:50 AM
jonfoc's Avatar
jonfoc
Seems to be as open a topic as "which tyres would you choose". A lot of people use k+n and some ITG. You'll get plenty of choices. I've always used k+n
Old Nov 19, 2012 | 09:58 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i doubt the oil can do any significant damage.
i've used k+n and itg, along with none branded cheap ones.
i used an ITG on my zetec turbo and caused no problems, even at 1.8BAR
Old Nov 19, 2012 | 10:05 AM
Rsmat's Avatar
Rsmat
I run a GGR group A filter @ 36psi... No dramas
Old Nov 19, 2012 | 10:23 AM
opposite lock's Avatar
opposite lock
K&N panel filter for me.
Old Nov 19, 2012 | 10:33 AM
RichieST's Avatar
RichieST
The oil only causes an issue if you use too much of it. The residue then coats the air flow meter which causes problems.
Old Nov 19, 2012 | 04:47 PM
v man's Avatar
v man
Zee Germans are coming
K&n panel filter with drilled air box
Old Nov 19, 2012 | 07:34 PM
Beetlejuice's Avatar
Beetlejuice
AEM Dryflow is the ultimate in my opinion.
Old Nov 19, 2012 | 07:49 PM
Ive used a pipercross cone filter and now im using a massive KnN cone filter.I had no issues with either.
Old Nov 19, 2012 | 08:23 PM
plynchy's Avatar
plynchy
On my second Pipercross, first one lasted 10 years. No problems at all. Oil only an issue if you have a MAF sensor I believe?
Matt Baxter
Sep 16, 2015 08:30 PM
cossirob
Aug 29, 2015 03:23 PM
Franko99
Aug 29, 2015 01:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
Escortdriver1
Aug 5, 2015 12:45 PM
