mk6 escort lower arm mod
im looking to swap the bushes out for spherical bearings. i just need some more info on which bearings i need to get for them. im fed up with eating lower arms lol. thanks
im not using camber adjustables atm im just fed up with goin through so many bushes lol. ive looked on google and ive also been to a local bearing specialist and they didnt know which bearing i needed
I know how you feel, felt like i was changing them monthly on my old gti especially once the 17s were on but tbh most of the time it was the ball joint that failed rather than the bushes so dont know how much fitting spherical will help you, unless your getting bush failure obviously lol
In our old Escort 1.8 the wishbones seemed to fail the MOT and need replaced every year for three years till I swapped the bushes for Powerflex polys. Didn't need replaced again after that until we got rid of the car at 11 years old so it was money well spent.
Yeah the ball joints are always fine its just the bush on the back end of the lower arm. I was goin to poly bush the rear beam but i brought a beam from ford fair not realising that a mk5 and mk6 are different bushes
jessie_rs
11
Jun 3, 2019 04:57 PM
