Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Mk1 Fiesta 1100cc 5 Speed Conversion
Old Nov 18, 2012 | 05:48 PM
Rogeyboy's Avatar
Rogeyboy
Default Mk1 Fiesta 1100cc 5 Speed Conversion
Anyone done this?
Im aware of the tie bar mod and possibility of cutting the inner wing, esp if we plan to fit a bigger engine in the future.
What about the flywheel/starter motor? The 1100cc in there uses an intertia starter motor, whereas the 5speed bc box bellhousing won't accept this older style of starter so i can't use the existing flywheel... I can't put a cvh flywheel on it either as theres only 5 bolt-holes in the 1100cc crank.
Ive had a google up and can't find any details on the starter/flywheel mods.
Any guides etc would be great?
Old Nov 18, 2012 | 06:18 PM
studabear's Avatar
studabear
Have a look at the fiesta centre website, they do kits so might have some answers.
Old Nov 24, 2012 | 10:33 AM
BLU's Avatar
BLU
BLU is the new black :)
I did this mod a couple of times back in the mid to late 90s. If you use a 5 speed box from a MK2 fiesta its a straight fit with 1100 flywheel and clutch. You just need the Fiesta centre kit to move the tie bar over to clear the 5 speed casing. The 950/1100 only needs the inner skin on the innerwing removing as the engine sits over towards the o/s, however if you're converting to Kent engine in the future it'll need the whole wing cutting out. The kent engine moves the box over towards the n/s and as such requires a different cradle and driveshafts.
Old Dec 7, 2012 | 05:36 PM
phil clegg's Avatar
phil clegg
xxxxxx
TPM961
Jan 15, 2018 10:50 AM
fordfiestamk3
Sep 11, 2015 12:52 PM
28
Sep 8, 2015 07:10 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
Ben26
Sep 3, 2015 07:55 PM
