cosworth throttle body small screw ??
Old Nov 17, 2012 | 06:24 PM
Thanasis's Avatar
Thanasis
Default cosworth throttle body small screw ??
Hello to all,does anyone know,what about this screw in the throttle body?what is the adjustment? thanks in advance.
photo sharing sites
Old Nov 17, 2012 | 07:00 PM
costina's Avatar
costina
Live long and prosper!!
don't touch it
its throttle plate adjustment messing with this can cause idle issues
Old Nov 17, 2012 | 07:12 PM
Thanasis's Avatar
Thanasis
Originally Posted by costina
don't touch it
I need to learn how to adjust it!
Old Nov 17, 2012 | 09:09 PM
costina's Avatar
costina
Ok i've measured 2 2wd throttle bodies the bit that sticks up thru body one measured 2.19mm and the other 2.51mm so i'd go half way between them both and ensure thottle opens and closes nice.
Hope that helps
Regards
Paul
Old Nov 17, 2012 | 09:22 PM
Thanasis's Avatar
Thanasis
Hope that helps
Regards
Paul
thank you very much Paul
Regards
Cosnada
Aug 27, 2015 09:15 AM
Dicko&Vacant
Aug 21, 2015 05:59 PM
nick8saff
Aug 16, 2015 05:35 PM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
