Mk 4 escort eclipse 1.3 ..... Knocking/vibration
Old Nov 17, 2012 | 05:07 PM
Linnnaim's Avatar
Linnnaim
Roy
Default Mk 4 escort eclipse 1.3 ..... Knocking/vibration
Hi , I've got a 1987 escort eclipse 1.3 ohv Valencia , it runs and drives fine , but when it's stood still in neutral and you rev the engine hard right up to the limit the engine vibrates and there is a rumbling noise and the gerstick vibrates like hell , only at the red line point up until then the engie sounds fine ... Out on the road it's fine until you really rev it when you go up hill it starts to kangaroo a bit ... Its got fairly new plugs and ht leads , done 34,000 miles , any ideas?? ... Sounds like the start of something bad !! Thanks ... Roy
Old Nov 21, 2012 | 03:06 PM
Linnnaim's Avatar
Linnnaim
Roy
Hi , I,ve been investigating a bit , and I have just removed the engine mount to see if that was the problem , I,m an engine mount virgin but it was fairly easy ... The mount looks spot on all the casing is solid and the rubber middle looks and feels like new , the only other mounts on the gearbox are solid tight ... So there out of the question ..... Must be internal engine or gearbox problem ????? Aaarrrggghhhh. Roy
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
