Granada hubs on a sapphire...
Old Nov 17, 2012 | 04:57 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
Default Granada hubs on a sapphire...
is it possible to swap 4x4 granada 5 stud hubs onto Sapph Cos?
i've found some wheels i really want, and 5x112 granny hubs makes more sense than pcd adaptors...
Old Nov 17, 2012 | 05:11 PM
dojj's Avatar
dojj
Resident Wrestling Legend
yes, it's a straight forward hub swap if you simply undo the big hub nut
however, with the inherant problems you may face, and the cost of changing the bearings as well as the potential for the hub nuts to strip the threads on the shafts, it may be easier to simply get some brackets made to get your brakes to fit
Old Nov 17, 2012 | 05:12 PM
dojj's Avatar
dojj
btw, been there, done that, same problems i had
Old Nov 17, 2012 | 05:26 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
are the brakes the same size front and back, then?
Old Nov 17, 2012 | 05:37 PM
dojj's Avatar
dojj
nope, the hub lugs have a different offset
Old Nov 17, 2012 | 05:51 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
hmmm. might just be a case of swap the flanges, then
Old Nov 17, 2012 | 06:39 PM
dojj's Avatar
dojj
you made need a press then,the bearings tend to rall apart when the things come out
Old Nov 17, 2012 | 07:35 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
I got a pair of hub completethat I was gonna use on my 3dr for just this purpose bit didn't in the end
Consequently they are for sale if your interested fella.
Old Nov 18, 2012 | 08:38 AM
Dont see many sierras with 5 stud wheels. Get the mod done matey.
Old Nov 18, 2012 | 08:45 AM
Bloomers's Avatar
Bloomers
Cornish Fasty
i'll need 4x4 ones bud, thanks for the offer, though
Glenn - Think it has to be. so limited for wheel choice by 4x108 nowadays
Old Nov 18, 2012 | 08:55 AM
dojj's Avatar
dojj
used to be able to buy them new from ford for £104 each back in the day
Old Nov 18, 2012 | 09:27 AM
foxy06's Avatar
foxy06
Whats the wheels??? Same PCD as my Audi.
Old Nov 18, 2012 | 11:07 AM
Iain Mac's Avatar
Iain Mac
I quite fancy 5 stud hubs just to be different but...
Did Granada/Scorpio 4x4 models get 5 stud wheels?
If they did, are the hub flanges a straight swap onto Sierra Cosworth 4x4 hubs and driveshafts?
If the didn't, can I use rear flanges on the front for Sierra Cosworth 4x4 hubs and driveshafts?
Old Nov 18, 2012 | 11:55 AM
dojj's Avatar
dojj
yes
yes
no as they are a different size on the bearings
Old Nov 18, 2012 | 12:33 PM
JonnyBravo's Avatar
JonnyBravo
My mate had his 500 converted to 5 stud ( keeping all the original parts though I might add )
Same story though, got some BBS split rims in 5 stud and had to have them on his car along with the 330mm 4 pots
Certainly looks epic on them !
Old Nov 18, 2012 | 03:16 PM
Defo looks nice that.Love these wheels on the 3dr cossies.
Old Nov 18, 2012 | 03:21 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
my idea...
but just having 5x112 leaves a myriad of possibilitys
Old Nov 18, 2012 | 03:24 PM
Wow there stunning.Defo do it.
Old Nov 18, 2012 | 04:13 PM
foxy06's Avatar
foxy06
Cool, or contact manufacturer and request if they can drill a blank set to Ford PCD if needed?
Old Feb 4, 2013 | 04:44 PM
lime's Avatar
lime
so if i have 4x4 hubs on a sapp all i have to do is change the flanges , and if i use the granada rotor will it fit the 2wd caliper
Old Feb 4, 2013 | 05:13 PM
dojj's Avatar
dojj
just drill some new holes in the disc to mount to the flange
you need to file out one of the holes and drill 4 more
easy if you know what you are doing but if you don't, then not as simple and straight forward as it sounds
Old Feb 4, 2013 | 05:18 PM
lime's Avatar
lime
hmm in that case i think i will jus buy some evo 8 calipers and a willwood disc to suit
Sierrasideways
Oct 8, 2015 06:37 PM
fordrallycar
Sep 30, 2015 07:57 PM
IainRS1700T
Sep 25, 2015 06:44 AM
cliffy70
Sep 20, 2015 09:18 PM
jc1989rs
Sep 5, 2015 08:09 PM
