Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Mk1 FRS key and key fob.
Old Nov 13, 2012 | 09:18 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Default Mk1 FRS key and key fob.
To save my blushes and my neighbours eardrums can anyone give me a quick run down on the correct use of the key and key fob for the Mk1 Focus RS. I read somewhere that you use the buttons on the standard key to lock (set the deadlocks) the car then press the larger button on the separate fob to alarm the car. Then to unlock the car you press the small button on the fob to deactivate the alarm and then use the key to unlock the deadlocks is this correct as i still keep setting the alarm off so i must be going wrong somewhere.
Cheers all.
Old Nov 14, 2012 | 06:35 AM
stevos's Avatar
stevos
Not sure mate but can tell you at the weekend when I buy mine
Old Nov 14, 2012 | 10:21 AM
Rsmat's Avatar
Rsmat
Make sure all doors are closed... Then lock using the key button... Then re-open with the RS fob and now use that from now on and not the key buttons as the alarms collide if open with one and lock with another and vis versa .
Old Nov 14, 2012 | 09:19 PM
STAFFY OWNER
Oh well done mate. Is it the one that you posted up about a few days ago? Get some picks up when you get it, i want to put some pics up of mine but it was raining all day on Monday when i got it and it's dark when i get in from work. Will get some up hopefully at the weekend.
Cheers Matt. Does that mean that the normal key is redundant for locking purposes and only used for turning the ignition on? So i just use the RS fob for locking and unlocking?
Old Nov 14, 2012 | 09:31 PM
stevos's Avatar
stevos
yep got that one and another one to go see so hopefully will bring at least one home.
defo get some picks up of yer car mate it looks lovely.
Old Nov 18, 2012 | 04:59 PM
STAFFY OWNER
How did you get on stevos? Did you manage to pick one of them up?
Old Nov 18, 2012 | 05:53 PM
pee vee's Avatar
pee vee
I just lock the car using the button on the key (deadlock) and then press the button on the rs fob... That way both alarms are set..
Then to unlock press the rs fob button ( that will unlock the doors). And then press the unlock button on the key. (if you open the door before that the standard ford alarm will go off)
Bit of a faff, but that way both alarms are armed for your peace of mind. Lol
Old Nov 18, 2012 | 05:55 PM
Zetecfiesta's Avatar
Zetecfiesta
If the alarm keeps going off after you have set it with above instructions id say the alarm is goosed whic is a common problem on FRS mk1
Old Nov 18, 2012 | 05:58 PM
jsXR3I's Avatar
jsXR3I
Just make sure u use the big button on the fob to lock and unlock. The small button on the fob is a panic button so the alarm will go off if u push that one.
Old Nov 20, 2012 | 01:15 AM
STAFFY OWNER
Cheers for that mate, wondered what the small button did. That's probably why the alarm keeps going off when i press it, i just thought i was not arming the alarm correctly as i didn't realise it was a panic alarm.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Tank Mike
Sep 26, 2015 08:07 AM
