Welding?
Old Nov 13, 2012 | 06:41 PM
leedsrhinos126's Avatar
leedsrhinos126
Default Welding?
I've got a mig welder and wanting to weld a stainless exhaust so whats needed to be able to do this?
Which gas is best? Argon?
Thanks
Old Nov 13, 2012 | 06:55 PM
crazycage's Avatar
crazycage
Thanks
innomax gas and a roll of stainless wire. pure argon is no good for mig stainless.
adam151082's Avatar
adam151082
I thought you needed a TIG welder?
Old Nov 13, 2012 | 06:57 PM
crazycage's Avatar
crazycage
imo you do but it can be done with a mig it will just look shit thats all.
Old Nov 13, 2012 | 08:07 PM
jamie956's Avatar
jamie956
I made my dads exhaust system on his cortina welded stainless tail pipes to the stainless back boxes, used a mig with normal gas and normal mild steel wire and to be fair its the neatest looking weld ive ever done, its been on for nearly two years and theres no rust.
Old Nov 13, 2012 | 08:28 PM
leedsrhinos126
Ummmmmm do you think i should give it a go then just using normal gas and wire? It's only welding a small straight pipe on
or buy propper stuff??
Old Nov 13, 2012 | 08:51 PM
jamie956's Avatar
jamie956
I'll admit you cant beat tig on s/s and alloy but for a one off small job i'd give it a go with what you have, may be have a play on a pice of scrap i think you need to set it quite hot.
if you doing pipe open the jaw of ya vice so the pipe sits on top half in/out get ya self steady and then get someone to turn the pipe as you weld,
Old Nov 13, 2012 | 09:05 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Stainless wire and argoshield light is what i use, doesn't come out too bad.
I have done all mine this way, exhaust system, boost pipes etc.
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
