Help no power to coil
Old Nov 13, 2012 | 01:52 PM
akamob's Avatar
akamob
Default Help no power to coil
I lost power to the coil on my 4x4. If you get a live straight from battery it starts. Any ideas what has died on me?
Cheers lee
Old Nov 13, 2012 | 02:21 PM
rog's Avatar
rog
Possibly the alarm has disabled the live feed.
Old Nov 13, 2012 | 02:29 PM
akamob's Avatar
akamob
It has not got an alarm on it.
Old Nov 13, 2012 | 02:41 PM
rog's Avatar
rog
Not even a Ford factory one?
Old Nov 13, 2012 | 02:45 PM
N.Saph's Avatar
N.Saph
New Ford sierra owner
possibly burn a bit of the loom somewere leading to the coil?
Old Nov 13, 2012 | 03:01 PM
akamob's Avatar
akamob
The factory alarm might still be on it but not sure
Old Nov 13, 2012 | 03:15 PM
rog's Avatar
rog
All standard 4x4 wiring??
Old Nov 13, 2012 | 03:55 PM
akamob's Avatar
akamob
Yea mate
Old Nov 13, 2012 | 08:40 PM
rog's Avatar
rog
http://www.bigturbo.co.uk/main6.htm Scroll down to L8 ECU diagram and that will explain it a bit, the ignition module it the ignition amplifier on the inner wing under the bonnet. Will get some more info for you soon, I need to look at the ignition barrell on the steering column to check how that is wired.
Old Nov 14, 2012 | 05:39 AM
akamob's Avatar
akamob
Cheers I been looking on big.turbo. Going to get an ignition amplifier to try today.
Old Nov 14, 2012 | 12:04 PM
martysmartie's Avatar
martysmartie
As said, if it's still got the standard immobilizer, then this is the most likely causing the problem, that or you have lost the live feed to the coil.
It has nothing to do with the ignition amp!
Martin
Old Nov 14, 2012 | 01:21 PM
akamob's Avatar
akamob
Where does the +live to the coil come from?
Old Nov 14, 2012 | 02:04 PM
rog's Avatar
rog
-The green wire connects to the iginition coil, this comes from the rev counter and ignition amplifier.
-The black wire connects to the black & yellow wire on the ignition amp, the black wire on the lambda sensor and the red positive wire from the ignition.
Old Nov 18, 2012 | 09:59 PM
mark r's Avatar
mark r
it lives faulty relay was the problem!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Iain Mac
Sep 30, 2015 09:39 PM
