How do you fit an under bonnet rev counter for tuning (removeable)
Old Nov 12, 2012 | 11:04 PM
Stu_K's Avatar
Stu_K
Default How do you fit an under bonnet rev counter for tuning (removeable)
Hi,
My S2 has a group A coil pack, and I need to wire up an under bonnet rev counter so that I can sort out the idle, timing etc.
Any one have any ideas?
Old Nov 12, 2012 | 11:12 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Best way would be to use a hand held automotive multi meter with an inductive pickup which clips onto one of the plug leads.
Old Nov 14, 2012 | 11:36 AM
black_jack's Avatar
black_jack
Black Jack
i have a couple of ideas - set a mirror so you can see the cars, rev counter when you are under the bonnet, or use aTV and camera,
some add-on rev counters (eg pod mounted) just need to have a wire wrapped round an ht lead, and power connected from the battery, many have switches for 4,6,8 cylinders, and read to 10K or more, they can be quite cheap
Old Nov 14, 2012 | 11:20 PM
chasemk2's Avatar
chasemk2
run off the green coil wire for feed
Old Nov 15, 2012 | 02:10 PM
Twizz's Avatar
Twizz
Out of many, we are one.
Run the green cable off the neg side of the coil.
Positive to switch live
White on illumination circuit
Black on earth
Old Nov 15, 2012 | 08:16 PM
Stu_K's Avatar
Stu_K
excellent, thanks chaps
Old Nov 15, 2012 | 09:28 PM
Twizz's Avatar
Twizz
To be honest, I'm sure you'd be able to run the red cable from the positive side of the coil... I believe thats a switched live (failing that, running it straight from the battery would do for setting up, just make sure you disconnect it after).
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
