Bizarre Fiesta heater problem
Old Nov 11, 2012 | 03:35 PM
thegfb's Avatar
thegfb
Skint V6 owner
Default Bizarre Fiesta heater problem
So, my Fiesta only blows cold air through the blowers no matter what the settings.
I checked the temperature of the inlet hose to the heater valve and it was warm, and cold on the other side. This suggested to me that the heater valve was busted (common problem) so I replaced it easily and cheaply enough.
It still blows cold air on all settings, however. I felt the hoses again and they are still warm on the engine side and cold the other side of the valve.
I guessed that I might have been unlucky and got a bad valve however I connected it up without the hoses connected and watched the valve move in and out as I turned the heater dial in the cabin.
I thought maybe the matrix is choked up so I flushed this through with the garden hose. Not only did nothing really much come out of it, but the flow was quite quick and it certainly didn't seem restrictive.
My problem is that something is forcing the warm coolant down the bypass in the heater valve even with the valve open, but I can't figure out what!!!
Any ideas please?
Old Nov 11, 2012 | 06:26 PM
cabriolet's Avatar
cabriolet
? maybe duff waterpump
Old Nov 12, 2012 | 08:13 AM
thegfb's Avatar
thegfb
Skint V6 owner
Hi cabriolet, the pump seems fine. I pulled a hose with it running and coolant came out then I quickly reconnected it.
The thermostat is good too, the engine warms up ok and sits at middle on the temp gauge the whole time.
One other thing I forgot to say - if the valve is unplugged, it should be letting coolant circulate through the matrix all the time. If I do this, it still blows cold air and the hoses stay warm on engine side and cold on the matrix side...
Wtf???
Old Nov 12, 2012 | 09:57 PM
steve_o's Avatar
steve_o
mite be a silly question but are the hoses going into the valve connected the right way round? dont know if that would make a difference or not?
Old Nov 12, 2012 | 10:42 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Is the replacement part new or second hand?
Genuine Ford or cheap motor factor/ebay jobby
rex647
Mar 6, 2022 06:20 AM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
