1990 mk4 escort bonus turbo w/cossie alloys - £1000
Old Nov 10, 2012 | 08:30 PM
m444rk's Avatar
m444rk
Default 1990 mk4 escort bonus turbo w/cossie alloys - £1000
1990 Ford Escort Bonus 1.1
MOT: Feb 2013
Tax: Feb 2013
Mileage: 95k (approx.)
Previous owners: 6
Purchased in March 2012 completely stripped out. Spent months rebuilding it to how it is now. The engine came out of a G reg RS Turbo owned by a mate of mine. The mileage on the engine when it came out of the RS Turbo was 90k. I have been using it as a daily driver, and it hasn’t skipped a beat over the 5k miles its covered since the transplant.
I would be happy to keep the car and finish it off, but in my area there has been a lot of thefts of old fords in the last couple of months. I thought mine was safe, but last week, someone drilled out the drivers door lock trying to get in. Now I can’t be bothered with the aggro of having to put the steering wheel lock on it and worry about whether it will still be there in the morning. So I’d rather get rid of it to someone who either lives in a nicer area or has somewhere safe to keep it like a garage. I’ve been brutally honest with every detail I can think of with the car, and although it sounds like a lot, they are all just small, niggly bits and pieces. There’s nothing major wrong with it, I commute in it and drive it on a daily basis. Just needs a bit of TLC and attention to finish it off. Im going to have a session on the car with my mate whos an expert with escorts in the next few days, so a lot of the issues ive listed may have been resolved.
I’m looking for a quick sale, as I have my eye on a mk6 fiesta. I think the £1k asking price is fair, as I know the cossie alloys can be sold for £400+, so effectively you’re getting a working turbo’d bonus for £600.
It is still registered as a 1.1, so the buyer would have to sort this out. I was running the car as a sleeper, It looks just like a bonus from the outside, with cosworth alloys.
- Engine set up by power engineering in 2007, running roughly 180bhp @ 10psi. Can be adjusted on the bleed valve.
- No service history, but has been owned by 2 old ford enthusiast friends who regularly serviced and took care of it. Last service was carried out in July.
- Bodywork is in fair condition, as you can see from the photos, there is filler on various parts of the bodywork, which has not been painted, but it is grey in colour, so doesn’t notice too much against the silver paintwork. OSF wing has been hit at some point, and has formed a tiny spot of rust which you can see coming through. If it was a major problem, a new wing could be purchased for around £40.
- Other than the spot of rust on the OSF wing damage, it is completely rust free.
- Small dent in the passenger door. Can’t really be noticed.
- Escort cosworth alloys which I purchased in August for £450. They have been sprayed in a very subtle blue/silver colour, but have various light kerb marks around the rims, so could do with a refurb. Tyres are toyo proxes, but rear 2 could do with replacing as the tread is quite low.
- The car is fairly loud due to the decatted stainless steel scorpion exhaust. This also makes the car rattle quite a lot at certain resonance levels. Another contributing factor to the rattling is due to some of the interior cards missing a couple of clips, so not sitting completely flush. This would be easily remedied.
- It has no stereo or speakers as I haven’t gotten round to fitting them yet.
- Passenger seat has collapsed a bit, and tends to wind itself down. This could do with replacing, but nothing major.
- Has a full rs turbo interior.
- 80 spec clocks, which are reading just over 41k. The handbrake light stays on constant. I’ve been told this could be to do with either the handbrake sensor, or the brake reservoir sensor needs cleaning. I haven’t gotten round to sorting it as it doesn’t affect the car in any way. The fuel indicator has a habit of never rising above half full. Im not sure if this is to do with fact it has a 90 spec loom and needs 90 spec clocks.
- Has the wiring and switch for electric mirrors, but I haven’t gotten round to fitting them, can throw them in with the sale.
- The fuel filler neck leaks slightly when filling with fuel, nothing major. Could do with fixing at some point.
- Electric windows and remote central locking fitted on the drivers side, haven’t gotten round to fitting the passenger side.
- Has a toad ai606 alarm and immobilizer, but the alarm siren does not sound. I bought a replacement siren to try and fix it, but it didn’t work. Not sure how to fix this.
- Engine starts on the turn of the key with a little gas on the pedal every time.
- Someone tried drilling out the drivers door lock, so this would need replacing. Only has 1 key and key fob, this only fits the ignition barrel, does not open the passenger door or boot lock. Could benefit from a new lock set.
- I installed a front heated screen, unfortunately only part of it seems to work, just various stripes and lines all the way along seem to heat up. This could be remedied with a hammer and a windscreen insurance claim.
- Clutch and LSD gearbox replaced by a friend and myself in July as the gearbox was knackered when I bought it. Pulls well through all gears.
- I believe the steering may need an adjustment, as the steering wheel sits ever so slightly to the left. Tracking and everything else is fine.
- Running gear was all taken off the RS turbo the engine came out of, as it got scrapped for being so rusty. So the brakes etc. are all present on this car.
- It has been lowered on the front and back and has uprated shocks on the front. It is quite low, as I find it will scrape speed bumps if you aren’t careful.
- Fitted a cosworth fan switch, so the fan kicks in a bit sooner, this meant that throughout the time I’ve owned it, the temperature gauge has never gone past half way.
- No rear seat belts have been fitted yet, apart from the centre belt.
- The clutch ratchet has a habit of popping and cracking occasionally. This is a £5 part, but is a pain in the a*se job, so haven’t done it yet.
- The light cluster seems to have developed a personality. The full beam lights do not switch on for around 10 minutes after starting, and the dipped beams for about 20 minutes. This is probably just something stupid which I’ll fix before selling. So for the first 20 minutes of driving, you only have sidelights. Which is handy in the winter.
- NSF lower ball joint needs replacing as its knocking slightly, and OSR trailing arm bush needs replacing too as its also knocking. Very inexpensive to do.
BASED IN THE CROYDON, SURREY AREA.
I'm sure I've forgotten loads of stuff and will take some pics of interior soon.
Thanks for looking.
*UPDATE*
took some pics of the interior today. Also remembered 2 more things to bear in mind with the car:
- no rear view mirror, I just never got round to sorting one out. you might have noticed from the earlier pictures there isn't one.
- the plastic collar behind the steering wheel was missing when I bought the car, I didn't have another one, so my mate cut down one from a mk3 escort and put that on it. Subsequently this means that the indicators aren't self cancelling and the horn doesn't work.
The passenger door card is missing in this photo, as I had the intention of sorting out the electric window and central locking, but never got round to it. I'll put the door card back on tomorrow.
Old Nov 10, 2012 | 08:51 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Total bargain mate! If you were closer I would have took this!
Old Nov 10, 2012 | 09:14 PM
Oh im tempted ,lol two silver ones
Old Nov 10, 2012 | 09:42 PM
Secret-Turbo's Avatar
Secret-Turbo
I hope you still have this in 2weeks
Old Nov 11, 2012 | 10:36 AM
Less.'s Avatar
Less.
having a mid life crisis
What a refreshing and honest advery and a bargain too it seems
Old Nov 11, 2012 | 10:56 AM
fiestaturbo1984's Avatar
fiestaturbo1984
If my bike sells i'll be coming to have a look at this
Old Nov 11, 2012 | 03:32 PM
m444rk's Avatar
m444rk
Thanks for the positive replies. i've just added photos of the interior and engine bay.
Old Nov 11, 2012 | 04:14 PM
Will be a nice toy for someone.It looks well on the escos wheels.
Old Nov 11, 2012 | 05:13 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
what a great car for the money, shame i dont have a spare grand
Old Nov 11, 2012 | 08:13 PM
Secret-Turbo
I will in a week or 2, but i doubt it will still be for sale
GLWTS though, i love it
Old Nov 12, 2012 | 06:17 PM
marksrsorion's Avatar
marksrsorion
How much with out the wheels?
Old Nov 12, 2012 | 08:03 PM
Tomm's Avatar
Tomm
I've probably totally missed it, but do you have a contact number?
Old Nov 12, 2012 | 08:04 PM
CHA114S's Avatar
CHA114S
I'll take the wheels. PM me. Then you can offer him the full amount.
Old Nov 12, 2012 | 08:25 PM
m444rk's Avatar
m444rk
The whole reason I put the car at the price was to avoid the hassle of selling them separately. I don't have any spare wheels to put on it. I can't separate them I'm afraid.
Old Nov 12, 2012 | 08:44 PM
ad4m mk4's Avatar
ad4m mk4
no smoke no poke
such a great looking car and with alot of potential, shame some people think they can take wat they want . had a similar problem with my modified mk4 fez someone tried to take it but obviously noticed the lack of a steering wheel. thank god for removable steering wheels lol
Old Nov 12, 2012 | 08:49 PM
CHA114S's Avatar
CHA114S
Wasn't asking u to mate. That's mine and the dude above's problem, not yours. He wants the car without wheels, I want the wheels, Pimm's o'clock!
Old Nov 12, 2012 | 09:25 PM
kizzy D's Avatar
kizzy D
Pm fella!!
Old Nov 18, 2012 | 05:08 PM
mgtkr1's Avatar
mgtkr1
is this still for sale?
Old Nov 18, 2012 | 05:42 PM
m444rk's Avatar
m444rk
Yes, still for sale!
Old Nov 29, 2012 | 12:26 AM
Secret-Turbo
Whats all that white stuff on the back seats ? :P
Old Nov 29, 2012 | 12:44 AM
Beach's Avatar
Beach
Bargain for a bag of sand that is!!!
Just too many things going on at the mo id love it for a daily driver though
Old Nov 29, 2012 | 06:36 PM
Secret-Turbo
PM sent.
Old Dec 17, 2012 | 12:18 PM
Dudley- boy's Avatar
Dudley- boy
Will u take 500 with our wheels ad I'll bring my own set thanks
Old Dec 17, 2012 | 12:23 PM
CHA114S's Avatar
CHA114S
Default How about...
You'd pass me if you're coming from Dudley. Take the whole car n I'll give you £300 for the wheels.
£500 from you, £300 fom me = £800 all in?
Come on, it's Xmas!!!
Old Dec 18, 2012 | 06:19 PM
Johnnyuno's Avatar
Johnnyuno
This car has been sold chaps i bought it about two weeks ago, just thought i would let you know.
Johnnyuno
Old Dec 18, 2012 | 06:41 PM
Secret-Turbo
Was hping to buy this myself, but the fella didnt reply to me when i asked for his phone number.,
Old Dec 19, 2012 | 02:39 PM
gyimesi's Avatar
gyimesi
love to buy this would make a perfect project
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
