Any BMW techs on here
Old Nov 10, 2012 | 12:11 PM
cossie891's Avatar
cossie891
Default Any BMW techs on here
As above really
Old Nov 10, 2012 | 12:23 PM
AlexF's Avatar
AlexF
yup
Old Nov 10, 2012 | 12:31 PM
cossie891's Avatar
cossie891
Are you a tech then mate
Old Nov 10, 2012 | 05:03 PM
cossie891's Avatar
cossie891
Anyone
Old Nov 10, 2012 | 05:04 PM
booner999's Avatar
booner999
what is the problem... not a tech but owned enough to point you in the right direction?
Old Nov 10, 2012 | 05:13 PM
cossie891's Avatar
cossie891
Hello mate my missus has a T plate E46 318i
Few probs
1st no number plate lights
2nd sometimes when I try to start it it just clicks and the head lights come on full wierd eh I can bump it and it will start but the indicators on the dash don't work but do outside. If I turn it off and restart it they work fine
3rd sometimes when we switch it off and pull the key out the oil light stays on the dash and the heaters keep blowing
The battery is fine as is the connections the starter is good as well so any ideas I was thinking the body control module
Old Nov 10, 2012 | 05:25 PM
booner999's Avatar
booner999
Number one: Common issue with the rear cluster for the number plate lights, we have this issue with our E46 330i Sport. Try a new bulb, try cleaning the terminals, failing that, take it apart and check the wiring on the back, check the wiring where the cables go from the car to the boot, if all else fails, buy a known working rear cluster (around Ł40 on ebay)
Number 2: Clicking is a sign of the battery being flat and not enough grunt to turn the starter... Could be a couple things in my eyes, starter is on its last legs, battery is flat or old and passed its best.... or another thing to try, give the terminals another turn on the battery... Had a simular issue before and this worked, was not tight enough and causing all kinds of electrical issues.
Number 3: Oil light staying on is telling you the oil is low, worry if it comes on when your driving... They have been known to throw a sensor and cause the lights to come on, replacement from BMW is not massive money, check your levels first though to make sure that is not the case.
Check earths, electrical issues can be caused by poor earth straps... Failing that, get it on the diagnostic machines... I know a good BMW specialist in Yeovil if your in shit
Old Nov 10, 2012 | 05:35 PM
cossie891's Avatar
cossie891
The bulbs are new and the cluster is fine too there is no broken wires to it either
The battery is fully charged when this happens and the starter is fine
The oil light shouldn't come on when the keys have been removed that's why all this is confusing
I think the lights might be the LMU
And the rest might be the body control module but I don't know for sure
I was hoping some 1 would know lol
Old Nov 10, 2012 | 05:37 PM
cossie891's Avatar
cossie891
I hate cars lol her last Beemer fucked up and turned out she need a new ECU she fixed it then eventually sold it and bought this 1 now this 1 is playing up
Old Nov 10, 2012 | 05:38 PM
booner999's Avatar
booner999
lol if none of what I have said is causing it then I would be looking in the same direction you are. Something is not happy with it. Could save alot of time by getting it on a diagnostics machine though mate
Old Nov 10, 2012 | 05:41 PM
cossie891's Avatar
cossie891
Yea that's what I am thinking dude pain in the arse bloody beemers lol
cossie891's Avatar
cossie891
It's defo electrical and all must be linked
Old Nov 10, 2012 | 06:00 PM
snoop69's Avatar
snoop69
Not sure if this applies but the e39 sometimes have ignition switch problems which share the same symptoms. On the e39 its a quick fix, not sure about yours though. Maybe worth googling 'ignition switch problems for 'your model'.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Kam B
Sep 24, 2015 10:40 AM
