My series1 resto
Just a few pics of me series1. It has been treated to 2 new inner sills and 2 new outer sills, and a bit of patching on the floor and a little hole in the boot filled in. Next on the agenda is a full frontend 2 new inner wings, outer wings and a front and back pannel. Then its off to the spray shop to get a good lick of paint inside and out.
little update. I decided to pull the front wings and front panel off it a couiple of weeks ago. Just going to get some prices of getting the new ford items fitted. The old wings and front panel were new but i wasnt happy with the way they lined up where they join at the corners on the scuttle, so off they came. Anyway if anyone is interested here is a small update
Looks like quite alot of work there. I remember when mine looked exactly like the pictures in your first post. It's as if you will never see the end, but it is worth it in the end.
It looks like you are doing it properly though so best of luck with it
These projects seem to have a tendancy to run away with themselves, it started of as a simple zvh conversion but ended up a full resto. I am in no rush though cause i have a 600 bandit and a stage3 2wd saph to entertain me so will be 100% when its done.
Rod-Tarry
237
Mar 18, 2016 09:13 PM
