Focus Headlights
Old Nov 9, 2012 | 11:28 AM
ermir's Avatar
ermir
FOCUS
Default Focus Headlights
hi guys thinking about converting my mk1 headlights to mk1.5. Are they better or i`ll have the same light at night? thanks
Old Nov 9, 2012 | 12:26 PM
STeve's Avatar
Super Moderator
they are not plug and play but apart from darker st170 ones looking better no real gains in performance
Old Nov 9, 2012 | 12:30 PM
melinamotor's Avatar
melinamotor
Farpylee
As said some fettling required to the wiring, also I concur the performance is no better to the Mk1's
Old Nov 9, 2012 | 04:23 PM
If you fit headlights out of the mk1.5 focus you will have 2 sets of indicators.A set in the headlights and the standard set in the front bumper.
The black ST 170 headlights look well.You could get a normal set of mk1.5 headlights and take them apart and paint them black inside.
Old Nov 9, 2012 | 05:08 PM
iansoutham's Avatar
iansoutham
OCD Victim
Rewire one of the sets to the sidelight circuit and put a 5W bulb in its place. I did the same to my sisters 1992 Escort when it had an XR/RS front bumper on it. The original indicators were clear anyway, os swapped the bulbs over, rewired to the sidelights and away they went. Same as the OE RS models, just a slightly wider light compared to normal. Most people would not notice.
Old Nov 12, 2012 | 08:43 AM
ermir's Avatar
ermir
FOCUS
iansouthman, i did the same. I did put amber indicators with 5w bulbs in and conected them with position lights. Now it looks light an amercian car. Also i converted the lights in mk 1.5. Big shit. I struggled three and i havent yet got hem center. It is not a good look also. thinking to get back the original ones again.
Old Nov 12, 2012 | 06:43 PM
thebigmacmoomin's Avatar
thebigmacmoomin
The lights are the same, in terms of the light they produce with the same bulbs.
The actual headlights dont swap straight around. The Mk1.5 lights are wired differently so a conversion loom will be needed. I managed to buy one when I put ST170 headlights on my Mk1. I never ended up with 2 indicators, the ones in the bumper worked as normal.
Old Nov 13, 2012 | 07:15 AM
ermir's Avatar
ermir
FOCUS
What a great look. That is what i wanted to realize. Hella indicators. But it dosnt look so good with the original bumper. Why didnt you put clear lenses in the headlights? Good job man!
Old Nov 13, 2012 | 10:34 AM
louis_2012's Avatar
louis_2012
There is a guide to which wire colour does what somewhere.
Old Nov 13, 2012 | 11:16 AM
ermir's Avatar
ermir
FOCUS
Yes in focusfanatics forum. It is not difficult to adopt but as mentioned before two pair of indicators doesn`t look pretty good.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Mile30
69
May 13, 2017 08:44 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
