mondeo st tdci common problems???
Old Nov 8, 2012 | 06:50 PM
disco-stu's Avatar
disco-stu
Default mondeo st tdci common problems???
could anyone tell me the common faults on the mondeo st tdci please im going to look at one at the weekend
Old Nov 8, 2012 | 10:02 PM
Cosnada's Avatar
Cosnada
Not wanting to sound off like but do a forum search - I for one listed one of the last 'what to look for' on these. I can't be arsed to type it all out everytime someone asks lol.
Maybe a nice mod can find the thread and put it as a sticky in the Mondeo section?
Old Nov 9, 2012 | 10:18 AM
thebigmacmoomin's Avatar
thebigmacmoomin
The only me & dad have had with our 2006 ST TDCi was the EGR valve went at about 35k miles. Now on 101k, its not any issues since that. The rear bumper saggs a bit now but thats a common issue.
One upgrade I would recommend is Focus ST front brakes (disks, pads & calipers). They are a straight fit aswell.
Old Nov 9, 2012 | 10:24 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Injectors
Diesel Pump
DMF
Some bearings or pulleys on the engine that make a horrendous grumbling noise
Rear calipers.
Old Nov 9, 2012 | 11:54 PM
bailey1's Avatar
bailey1
As above really but the most common are crank pulley/aux belt tensioner they cause knocking on idle then there's the egr valves /injectors /dmf's and when you drop subframe to change the captive nuts brake the welds in the subframe which is a pain on the near side as you have to open the chassis then weld back up/ early ones suffered with rear subframe bushes but most were sorted from factory/rear washer jet always pops its joint on inside of car in quarter panel/rear tyres always wear out of shape if you run budget tyres!!/high mileage wheels always seem to corrode and leak from around the bead/apart from that with reg services and especially fuel filter changes they are pretty bullet proof!!! Like any car mate if your buying one get the best you can for your budget and if been looked after most issues would of been done by previous owners. Hope I haven't put you off too much lol!!!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
talon1
Sep 15, 2015 10:27 AM
marky_g
Sep 12, 2015 04:26 PM
hopper350
Sep 4, 2015 12:53 AM
