sierra cosworth group a parts for sale (insert ratings added)
Old Nov 6, 2012 | 06:27 PM
3dr cossie's Avatar
3dr cossie
Default sierra cosworth group a parts for sale (insert ratings added)
genuine ford group A front bilstien coilovers with eibach springs, 50mm inserts, VGC no leaks £250
genuine ford group A rear gravel spec bilstien coilovers, complete with springs and helper springs, no leaks VGC £250
4x4 front hubs £50
Brand new square beam bushes, bought from dewitts £30
also have another set of 909 bilsteins, fronts have brand new 43mm inserts bought from dewitts, the inserts have never been fitted into the bodies looking for £300 ono
also have a second set of very good rear 909 coilovers, looking for £300 ono
full length kevlar sump guard, believed to be ford 909 part £125 ono
will get pics soon
Cheers Matthew
Old Nov 7, 2012 | 05:35 PM
3dr cossie's Avatar
3dr cossie
new parts added
cheers Matthew
Old Nov 7, 2012 | 06:23 PM
Mr RS500's Avatar
Mr RS500
The 4x4 coss front hubs , is it £50 the pair or each ?
Paul
Old Nov 7, 2012 | 07:33 PM
3dr cossie's Avatar
3dr cossie
Sorry just found out they are xr4x4 front hubs
Cheers Matthew
Old Nov 8, 2012 | 09:48 AM
Rozvor's Avatar
Rozvor
Are 4x4 or 2WD?
Old Nov 8, 2012 | 11:40 AM
3dr cossie's Avatar
3dr cossie
in order to fit hem, you need 4x4 front hubs, as the bottom of the shock is wider than a 2wd version, thats why i have xr4x4 front hubs for sale aswell
cheers Matthew
Old Nov 8, 2012 | 08:09 PM
Rozvor's Avatar
Rozvor
cheers Matthew
Thanks, but I've 2WD brakes and change all is very expensive
Old Nov 10, 2012 | 11:28 PM
whizzisat114's Avatar
whizzisat114
Where about are you in the country?
Old Nov 11, 2012 | 04:44 PM
pepsimax escort's Avatar
pepsimax escort
Whar are the damper rates for the Bilstein re coil overs and spring rates?
Graham
07813643319
Old Nov 11, 2012 | 05:00 PM
3dr cossie's Avatar
3dr cossie
Hi I'm in morecambe, Lancashire
Cheers Matthew
Old Nov 11, 2012 | 05:01 PM
3dr cossie's Avatar
3dr cossie
Graham
07813643319
Hi graham
Not sure I'll have a look and post any markings they have on them
Cheers Matthew
Old Nov 11, 2012 | 06:20 PM
lee2cossies's Avatar
lee2cossies
Did u manage to get a price for postage on steering wheel?
Old Nov 11, 2012 | 07:33 PM
3dr cossie's Avatar
3dr cossie
Hi postage and packaging will be £12
Cheers Matthew
Old Nov 14, 2012 | 05:14 PM
Moonshine's Avatar
Moonshine
Hi there,
What kind of car have the front suspension legs come off? What I'm asking is, what spec group A car -gravel, Tarmac etc . . .? Is there any adjustment on them apart from height?
Also, will they just go straight into a road car - top mount wise?
Lastly, can you pm or post on here your contact number - I find it's almost always easier to talk to someone than email about all over the place.
Old Nov 16, 2012 | 09:40 AM
3dr cossie's Avatar
3dr cossie
Originally Posted by Moonshine
Hi there,
hi, holding off selling any of the billys as i may have found new storage for the car they were intended for
cheers Matthew
Old Nov 16, 2012 | 09:41 AM
3dr cossie's Avatar
3dr cossie
steering wheel now sold
cheers Matthew
Old Nov 19, 2012 | 09:06 PM
anglia105e hinson's Avatar
anglia105e hinson
Alright mate do to still have the clutch?
I'm desperate !!!
Old Dec 20, 2012 | 09:02 AM
3dr cossie's Avatar
3dr cossie
more group A suspension parts added
cheers Matthew
Old Dec 20, 2012 | 09:04 AM
3dr cossie's Avatar
3dr cossie
Hi there,
Hi there is only height adjustment, as if you want to change dampening you have to change the inserts
not sure if the fronts go striaght on a road car on the top mount, but the rears go straight on
cheers Matthew
Old Dec 20, 2012 | 12:13 PM
Paul_RS's Avatar
Paul_RS
Where you able to get the damper ratings for the Bilsteins matey?
Old Dec 20, 2012 | 01:59 PM
3dr cossie's Avatar
3dr cossie
I'll have a look today, they are on the inserts?
Cheers Matthew
Old Dec 21, 2012 | 09:57 AM
Paul_RS's Avatar
Paul_RS
Should be at the top of them matey
Old Dec 21, 2012 | 11:06 AM
3dr cossie's Avatar
3dr cossie
the fronts will but not sure on the rears, which are you interested in?
cheers Matthew
Old Dec 21, 2012 | 02:29 PM
Paul_RS's Avatar
Paul_RS
Sorry, should have said it was the fronts
The rears usually have the ratings of a part number stamped into the bottom of the housing, under the height adjustment threads.
Old Dec 28, 2012 | 06:25 AM
3dr cossie's Avatar
3dr cossie
Right got the insert ratings for all 4 sets of coilovers
Firstly,
50mm insert fronts say 425/140
43mm insert fronts say 450/120
Rears as pictured say 350/150
The second better rear set say 260/110
Cheers Matthew
Old Jan 3, 2013 | 03:38 PM
3dr cossie's Avatar
3dr cossie
open to offers
cheers Matthew
Old Jan 5, 2013 | 03:26 PM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Are you intrested Paul ?
If not i am tempted mate ...but can wait in line
Was intrested in the full set
Old Jan 9, 2013 | 06:44 PM
3dr cossie's Avatar
3dr cossie
50mm front coilovers and 4x4 hubs sold pending payment, everything else still available
Cheers Matthew
Old Jan 9, 2013 | 06:45 PM
carl/saff's Avatar
carl/saff
Cheers Matthew
No worries
Old Jan 25, 2013 | 04:40 PM
William MK2 Cosworth's Avatar
Free bump!!
Got the coilovers and hubs today!
very nicely packed aswell!
Old Jan 26, 2013 | 03:05 PM
marco polo's Avatar
marco polo
the 260- 110 are gravel spec
the 350- 150 are tarmac
Old Jan 26, 2013 | 05:22 PM
3dr cossie's Avatar
3dr cossie
Cheers for the info
Old Feb 13, 2013 | 11:31 PM
janvanv's Avatar
janvanv
www.rallyanarchy.com
I think you'll find that 350/130 with 190mm travel are Escort Cos front gravel
260/90 was early 3 door gravel
And that works very well as fast road car inserts combined with a spring between 275 to 325 lb/in.
When you see 425/160 or 500/200 you know you have tarmac...
The 160mm travel of the tarmac inserts is another hint...
It's no major problem fitting GpA inserts into standard road car shells..
There's two tops basically GpN and Group A:
The fat 20mm pin is the Group A..
All you need is some of those things on the lower left and a nice spherical bearing--
-Ford used an expensive 22mm ID high misalignment bearing, I use a 7/8" on (22mm is .866", 7/8" is .875) and some skinny spacers---I make them in stainless steel.
You can get rel nice copies in the UK for about twice what they cost over in USA
Remember, 2wd cars the strut bottom is 45.5mm, 4wd is 50,8mm.
This suspension stuff is how I mainly pay the mortgage.
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
