Hi idle problem Ford Focus Mk1
Just got a Ford focus mark 1 (2002).
Has a really bad high idle problem. Whenever I stop (junctions,lights etc.) engine surges to about 2000 revs, then after about 5 seconds drops to 1000 but still sounds too loud and too racey.
Also when crawling along in traffic jams I have to keep jabbing the brakes, stop me crashing in to the car inn front and when I release brakes car accelerates itself!
I've replaced throttle position sensor and cleaned out idle air control valve (reset ECU each time). No OBD fault codes.
Weird thing is, if I put front and rear screen heaters on, revs drop to 750 which is spot on but I can't drive around with my screen heaters on all the time
Any ideas please?
Andy
Any ideas please?
Andy
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
