how will i work this out? diffs
Old Nov 4, 2012 | 07:25 PM
clyde 1800's Avatar
clyde 1800
Default how will i work this out? diffs
bought a job lot of stuff today some of which was diffs
got a standard 3.62
and a box of cogs along with an empty case
one crownwheel has 3.92 on it and another one i cant read
the casing has 14 teeth on the pinion
basically i need to work out which crown wheel is for this casing and which one is spare??
Old Nov 4, 2012 | 08:52 PM
clyde 1800's Avatar
clyde 1800
A=3.36(crown wheel 44 teeth, pinion 13 teeth, 7.5" diff casing) B=3.77 D=3.92(crown wheel 51 teeth,pinion 13 teeth, 7" diff casing )
F=3.842 J=4.056 K=3.31
M=3.14(crown wheel 47 teeth, pinion 15 teeth, 7"/7.5" diff casing) N=4.29 P=3.58
U=3.62(7" diff casing) V=3.33(crown wheel 47 teeth, pinion 13 teeth, 7" diff casing) Z=3.59
2=4.27 3=3.62 / 3.64? 4=3.82
5=3.26 6=3.12 8=3.56
9=3.91(7.5" diff casing)
Old Nov 4, 2012 | 08:54 PM
clyde 1800's Avatar
clyde 1800
the mystery crownwheel has 51 teeth and the pinion has 14
the spare crownwheel has 3.9 stamped
Old Nov 5, 2012 | 05:43 PM
clyde 1800's Avatar
clyde 1800
ok the fella rung me today and told me id left behind a diff casing
top bloke
all i need to do now is work out which crownwheel is for which diff?
one is fatter than the other and one casing is a 7.5 and the other is a 7
Chas
Sep 21, 2015 08:57 PM
mattman1234
15
Aug 14, 2015 10:05 PM
Gadget
Aug 13, 2015 08:19 PM
COLEYST200
Aug 3, 2015 08:55 AM
