Rebuilt zero miles EFI engine, recon turbo, lsd box
Old Nov 3, 2012 | 09:34 AM
Steve Escos's Avatar
Steve Escos
Default Rebuilt zero miles EFI engine, recon turbo, lsd box
Fully rebuilt efi engine
EFI engine, fully rebuilt consisiting of:
Crank re-grind and polish -0.25 mains and bigs
New heavy duty mains, big end bearings ACL
ARP 5/16th bolts
Refurbished and powder coated Genuine sump
New Oil pump
New waterpump
Payen head gasket
Bottom and top end gasket set
Payen stretch head bolts
Fully refurbished cylinder head
Newmans cam (FORC/276/409T PH4)
Newmans solid lifters/followers/tappets
Piper vernier adj pulley
0 miles never run £650 LOWERED PRICE £550
Would consider splitting head and bottom end but would need confirmed buyers first
Parts located in Scunthorpe but may be able to organise delivery. Steve 07725238098
Old Nov 3, 2012 | 10:05 AM
RSTurbo75's Avatar
RSTurbo75
Newcastle FC
Hi mate,
Who did the efi conversion on your engine? I'm in Grimsby and have a 2.0 zvh (st170 bottom end) and i'm looking to have it converted to an efi set up. Can you help?
Thanks
Old Nov 3, 2012 | 06:54 PM
Steve Escos
I have done the sourcing of parts. most things are easy enough to find. I did have the bespoke loom made for me and you would be looking at around £600 for a similar loom. That said every connector is brand new.
What do you need to know?
Old Nov 4, 2012 | 09:45 AM
RSTurbo75's Avatar
RSTurbo75
Newcastle FC
Hi Steve,
I'm on with sourcing some of the parts for the coversion but i needed somebody in the know to do the work on it. I would be definatly intrested in having a loom made up for it. I'm bidding on ebay on a complete efi inlet manifold
Old Nov 4, 2012 | 09:46 AM
RSTurbo75's Avatar
RSTurbo75
Newcastle FC
So i guess thats a start.
Thanks
Ryan
Old Nov 4, 2012 | 11:00 AM
Steve Escos
I most likely have everything you need twice over. I can talk you through things if you want give me a ring on 07725238098. Steve
Old Nov 13, 2012 | 07:04 PM
Steve Escos
Up advert updated
Old Nov 20, 2012 | 09:17 PM
RS_Rob's Avatar
RS_Rob
any pics of the gearbox please
Old Nov 20, 2012 | 11:19 PM
Dan F's Avatar
Dan F
As above Steve
Old Nov 21, 2012 | 03:47 AM
Steve Escos
Will get some at weekend as travelling with work however it is a s1gearbox painted gloss black has the hole for the front mount as per mk3 escort and definitely has an lsd .
Old Dec 26, 2012 | 07:30 PM
Steve Escos
up for post xmas
Old Dec 27, 2012 | 06:00 PM
stwibs's Avatar
stwibs
don't suppose you have a new year sale on ????
Old Dec 27, 2012 | 06:07 PM
davidfox280585's Avatar
davidfox280585
look forward to collecting the box steve see you soon
Old Dec 27, 2012 | 06:53 PM
Steve Escos
why what you after lol
Old Jan 1, 2013 | 08:35 AM
Steve Escos
new lower price on engine will also come complete with efi inlet and throttlebody
Old Jan 2, 2013 | 01:43 PM
Steve Escos
Engine pics added
Old Jan 7, 2013 | 07:36 PM
Steve Escos
Up for the new year
Old Jan 9, 2013 | 03:20 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Is there a cps hole/plug?
Old Jan 9, 2013 | 05:51 PM
Steve Escos
Yep definitely efi block and head.
Old Jan 10, 2013 | 02:10 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Seriously tempted! my bottom end i bought requires complete rebuilding! my head is standard with standard cam! can you pm me everything that comes with the engine and a total price including delivery? ive sent engines before and its not that expensive tbh! cheers
Old Jan 13, 2013 | 07:00 PM
Steve Escos
Will consider splitting bottom end and head
Old Jan 14, 2013 | 12:30 AM
Karl22's Avatar
Karl22
Hi mate im looking at putting one of these into a mk5 fiesta what other parts wud i need much help appreciated thanks karl
Old Jan 14, 2013 | 05:53 AM
Steve Escos
Loom ecu and sensors. Turbo, inlet and some hoses.
Old Jan 14, 2013 | 11:38 AM
Karl22's Avatar
Karl22
Thanks mate ill source them parts first before i buy a block and would that be a efi inlet id need and do i need a metering unit
Old Jan 14, 2013 | 11:51 AM
Steve Escos
Efi inlet I can help you with. No metering unit needed. I have some hoses which could go with engine. I need to check but may have nearly everything you need.
Old Jan 14, 2013 | 12:07 PM
Karl22's Avatar
Karl22
How much would u want for engine wiv the efi inlet and throttle body?
Old Jan 14, 2013 | 12:31 PM
Steve Escos
Would throw the inlet and throttle body in with the engine. All other parts would be extra.
Old Jan 14, 2013 | 12:41 PM
Karl22's Avatar
Karl22
Ok steve thanks come bk to me wiv a average price on the engine wiv the inlet and hoses needed if u can please
Old Jan 14, 2013 | 12:43 PM
Karl22's Avatar
Karl22
And is the inlet the one wiv crossover pipe wiv turbo written on it?
Old Jan 20, 2013 | 10:35 PM
Piston Broke's Avatar
Piston Broke
You got a turbo for sale ?
Old Jan 21, 2013 | 06:56 AM
Steve Escos
I have a t3 but has some play.was working fine £50 plus post.
Old Jan 21, 2013 | 08:30 AM
Piston Broke
Brill fella PM sent to you !
Old Jan 28, 2013 | 04:36 PM
Steve Escos
Back up
Old Jan 28, 2013 | 05:05 PM
Lee Reynolds's Avatar
Lee Reynolds
It's 'with'!
Old Feb 3, 2013 | 11:28 AM
Steve Escos
Up again no one want a cheap engine?
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
EoinXR3
Sep 7, 2015 05:44 AM
jaimesdna
Aug 25, 2015 06:59 AM
marky_g
Aug 15, 2015 10:43 AM
