Any Reno techs on?
Old Nov 1, 2012 | 06:25 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default Any Reno techs on?
I said I'd do rear discs and pads on a grand senic these have an electric hand brake what's the score with them? I've read if you pull the release lever while pushing the centre button as you turn the car off then remove the key card the hand brake will stay off then you just change the pads as normal
Old Nov 1, 2012 | 08:41 PM
ajamesc's Avatar
ajamesc
No one knows any thing about Renaults then lol
Old Nov 1, 2012 | 08:48 PM
saph4be's Avatar
saph4be
normaly need turning off then resetting!
Old Nov 1, 2012 | 08:50 PM
ajamesc's Avatar
ajamesc
no idea mate I work on trucks not cars so never messed about with one
Old Nov 1, 2012 | 08:52 PM
saph4be's Avatar
saph4be
thats the general rule i done a couple off other makes but not a renault!
Old Nov 1, 2012 | 08:58 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
dont know about the handbrake but when you get the discs, get the ones with bearings fitted. renault use a clip to retain the wheel bearing that you cant get out.
Old Nov 1, 2012 | 09:03 PM
ajamesc's Avatar
ajamesc
they do have the bearings fitted the job will be easy as long as I can release the park brake to do them lol
Old Nov 1, 2012 | 10:13 PM
jamie's's Avatar
jamie's
put the card in the reader, hold in the start button but DONT press the brake or the clutch pedals, after 5(i think) secs the ignition will come on but it doesn't start, now just use the lever/switch thingy to put the handbrake off, then just jack up and change pads as usual, been a while since i've done a set but i'm sure thats how i do them,
just obviously make sure you pump up the brake pedal after fitting but before turning ignition off or touching the handbrake lever/switch thingy again, as if the piston isnt pumped up the motors will have a hissy fit, the calipers are just normal wind back pistons, they even have handbrake ables going to them, the electric part is just 2 small motors mounted on the rear axle that pulls he cables on and off so nothing fancy like the passats and new audi's with the motor built into the calipers that need to be reset on the diagnostic machine, simples
Old Nov 2, 2012 | 09:38 AM
ajamesc's Avatar
ajamesc
Cheers ill give it a go
Old Nov 2, 2012 | 10:00 AM
andi-p's Avatar
andi-p
Dont renault calipers have the wind back calipers which one is normal and the other side is the opposite way round. A normal wind back tool wont turn it back in.
Old Nov 2, 2012 | 10:04 AM
ajamesc's Avatar
ajamesc
i have a wind back tool that dose left or right
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
