sierra cos/xr 4x4 front hubs on mk4 cos??
i learnt yesterday that the sierra xr/rs front hubs are differnt
front shock mounting angle
calliper mounting position
steering arm
https://passionford.com/forum/genera...ront-hubs.html
anyway i found this out after fitting new discs/pads on my car & noticing 1 calliper is 10mm away from the back of the rim & 1 is basically touching!
also then that 1 wheel sits at a very slightly differnt angle to the other (obv due to the shock mount differnce)
im just wondering why the actual shock angle is differnt as a xr sierra use's basically the same shell set up/suspension as an rs & to be honest the xr front hub works abit better on my car as its a mk4 escort cos & with the sierra width being wider then the escort this makes the offset look slightly better (wheels dont stick out as much) & helps the aid of my rs tubro rims as they are fwd offset.
so i have to purchase 1 hub to match a pair on my car & was wondering if a pair of xr hubs would mess up handling etc...
atm i am pointing towards buying rs hubs just to keep everything rite
anyone give me any advice??????
steering arm
I'm trying to work out something similar with mine rwd mk3, any pictures of the 2 differing sides? Or can u estimate the poke difference in mm?
Also u sure u got that around the right way that it the xr hubs that narrows the track??
charliecosworth
Aug 19, 2015 02:00 PM
