lean burn and hemispherical heads interchangable
Old Oct 25, 2012 | 07:37 AM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Default lean burn and hemispherical heads interchangable
As above really,
I got a carbed cvh which is my daily and wanted to get the head ported etc, I believe the head on my carbed engine is a lean burn (heart shaped) but dont really wanna go without a car whilst i get the head work done so i was thinking of using a turbo one.
Are they both interchangeable?
Old Oct 25, 2012 | 08:42 PM
Jamie_EscortSport
Anyone...
Old Oct 25, 2012 | 09:02 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
if the combustion chambers are different shapes, one heart shaped and one round, the 2 are not interchangeable unless you change the pistons also
Sean.
Old Oct 25, 2012 | 09:08 PM
Jamie_EscortSport
I had a feeling that was the case...o well ill just take car off the road for a while
CheeRS sean
Old Oct 25, 2012 | 09:10 PM
Cossie Sean
im sure you will find the right head easily enough for cheap matey
Buy cheap head, send that off and fit when its done
Nov 1, 2015 06:53 PM
Rsmat
89
Oct 12, 2015 07:50 AM
Mc5506
Oct 5, 2015 09:57 PM
