fiesta rs turbo problem
Old Oct 20, 2012 | 12:55 PM
ford addict's Avatar
ford addict
Default fiesta rs turbo problem
hello to everyone,i am doing a re shell of a fiesta rs turbo.today i tried to start it and after some time it started but idled for 2/3 seconds.the car has been standing for 3 years but i can hear the pump working and there seems to be fuel to the injectors.i replaced the idling control valve ,coil,throttle position sensor but no results.i checked the timing again and it seems to be right.
has anyone got a clue please as to what might be the cause?
thanks in advance
Old Oct 20, 2012 | 01:23 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Had this myself on my OFAB fiesta rs turbo, turned out to be MAP sensor.
Old Oct 20, 2012 | 01:39 PM
ford addict
hello adam can you tell me which one is the map sensor?
Old Oct 20, 2012 | 01:46 PM
Adam31's Avatar
Adam31
Waiting on my fast ford..
There will be a small black hose going from the inlet manifold to a sensore bolted to the scuttle panel, near to the EDIS plug, thats the MAP sensor.
Old Oct 20, 2012 | 02:38 PM
vaughant's Avatar
vaughant
Map is a good shout,did the same on my mates escos,everything seemed fine then just failed to start one day.
Also crap petrol doesn't help,shove some octane boost in.
You could also try the old deodorant in the airbox trick,will run for about 15 secs then,could be enough to drag the fuel through etc.
Old Oct 20, 2012 | 08:50 PM
Adam.'s Avatar
Adam.
As above
Old Oct 21, 2012 | 07:13 PM
ford addict
i ll check all the hoses and regarding the fuel i just put in new fuel along with new fuel lines this week.there is a small hose on the left side of the throttle body(where there is efi written)where does it go to?
carlo
24
Oct 5, 2015 08:20 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
turbobill
Aug 1, 2015 08:55 PM
