2004 cmax 1.8 zetec only starts when throttle pumped
Old Oct 19, 2012 | 06:16 PM
gouch1's Avatar
gouch1
Default 2004 cmax 1.8 zetec only starts when throttle pumped
as above not my car a mtes but he has to pump the throttle whilst crancking engine over for it to start
any ideas
Old Oct 19, 2012 | 06:20 PM
Carlos-Titx's Avatar
Carlos-Titx
Is it a diesel?
Old Oct 19, 2012 | 06:49 PM
gouch1's Avatar
gouch1
no petrol
Old Oct 19, 2012 | 07:01 PM
gouch1's Avatar
gouch1
bump................
Old Oct 19, 2012 | 07:24 PM
vaughant's Avatar
vaughant
Try disconnecting the throttle position switch then see if it goes.
I had this years ago on a zetec and it was that,I think it gives a false reading to the ecu or something.
Otherwise get the codes read first,it could be literally anything,low fuel pressure,dodgy crank /cam sensor,injector,fuel pump,wiring.
Porplus12
Sep 10, 2015 07:20 PM
Dubs44
Aug 21, 2015 02:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
gingerturbo
Aug 11, 2015 09:44 PM
