Mk5 fiesta rear hub bolts
Old Oct 18, 2012 | 10:59 PM
fraz2013's Avatar
fraz2013
Default Mk5 fiesta rear hub bolts
Hey all,
Im taking off the rear hub from my mk5 fiesta and there seems to be 4 bolts holding it in place, would like to ask a few q's, firstly is it pretty straight forward to remove the rear hub? and what type of socket would i require to remove these 4 bolts and what size?
Thanks in advance to everybody.
Regards
Fraz2013
Old Oct 18, 2012 | 11:02 PM
botters's Avatar
botters
competant bodger
may i ask first why are you removing the rear hub?
Old Oct 18, 2012 | 11:15 PM
fraz2013's Avatar
fraz2013
when i was investigating a grinding noise from the rear when i was braking, i jacked the car up and took the rear wheel off and drum off, and unfortunately i didnt have any axle's stands and thought i could get away with jacking the car up and having a quick butchers at it without axle stands. How wrong i was as the jack collapsed and took the stub with it and now only option is to replace it. Its a lesson learnt.
Old Oct 18, 2012 | 11:27 PM
botters's Avatar
botters
competant bodger
ah cool i see from memory its just 4 13 mm bolts
Old Oct 19, 2012 | 12:48 AM
Dan j's Avatar
Dan j
Van modder
Once bolts are out give the back of the hub a whack with a mallet and it will come off.
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
turbobill
Aug 1, 2015 08:55 PM
