Msd coil pack and leads..
I have for sale my new and never fitted.
http://i169.photobucket.com/albums/u...pseb738233.jpg
MSD Hyperpower Blaster Ignition system - CFM
New MSD Hyper power ignition system.
These new bolt-in coils are designed with improved materials and windings to produce a much stronger spark. This improved spark helps burn the fuel mixture more efficiently resulting in a smooth idle and improved mid range rpm power.
The MSD 8.5mm Super Conductor Wire is "the" performance wire. Engineered from the inside out, the 8.5 offers everything you have everwanted in a wire; incredibly low resistance without electronic interference! In a single 12 inch length of Super Conductor Wire there is only 40 - 50 ohms of resistance! That is the lowest resistance of any helically wound wire. To accomplish this, MSD uses a copper alloy conductor due to it's great voltage carrying capabilities. The low resistance results in less loss in spark energy so more reaches the spark plug. The conductor is wound extremely tight around a special center core. So tight in fact, that there is over 40 feet of conductor wrapped into a single foot of plug wire. This winding procedure, combined with a ferro-magnetic impregnated center core, produces an extremely effective Electro Magnetic Interference (EMI) "choke". This choke, or suppression capability, keeps the EMI inside the wire where it cannot interfere with other electronics on your vehicle. The outer sleeve that surrounds the conductor assembly is just as impressive. A proprietary blend of silicone and synthetic material produce a sleeve that is highly resistant to high heat as well as abrasion and tears.
The leads are blue with this..
£130
- 100% spark every time.
- The full system as shown replaces the whole of the spark generation system.
- Supplied with red leads unless out of stock then we supply black instead
- The new coil has a push and click system that guarantees connection every time.
- These coil packs do not fit seperatly on the focus and RS.
£130
