Heater problems on my x reg escort estate.
Old Oct 16, 2012 | 11:32 AM
Nicky82's Avatar
Nicky82
Default Heater problems on my x reg escort estate.
Hi there. I have no heating in my car at all. I put the gans on and all i get is cold air. It takes ages to demist my windscreen and i was wondering if anyone had any ideas to help as its freezing in there!! Thanks for the help guys
Old Oct 16, 2012 | 07:23 PM
Bungle's Avatar
Bungle
Heater matrix? There's 2 rubber pipes going into the bulk head to the right of your inlet manifold as you look at it check there not joined together if they are it points to a duff matrix and someone's bypassed it.
Failing that I'd be lookin at the cooling system
Old Oct 16, 2012 | 07:30 PM
stevo123's Avatar
stevo123
+1 to joined coolant pipes at the bulk head due to leaking matrix. Although it could be as simple as one of the control cables from the heater control becoming detached from the mechanism under the dash. Have a look under there - there is lots of access and they are easy to check
Old Oct 16, 2012 | 07:35 PM
STeve's Avatar
Super Moderator
also no thermostat to stop overheating was another one
Old Oct 16, 2012 | 07:59 PM
Twizz's Avatar
Twizz
Out of many, we are one.
+1 Does the temperature come up at all? Running no thermostat would make the car in most cases not heat up sufficiently enough.
Old Oct 18, 2012 | 08:38 AM
Nicky82's Avatar
Nicky82
hi guys. thanks for replying. i only have cold air blowing out and it doesnt heat up at all. the more i drive the foggier the windscreen gets and it gets foggy quickly if i wake the fan up to max aswell.
Old Oct 18, 2012 | 09:09 AM
RichieST's Avatar
RichieST
Does the engine come up to temperature ok?
Old Oct 18, 2012 | 12:37 PM
martysmartie's Avatar
martysmartie
As said the first thing you need to verify is that it reaches normal operating temperature, if not then it's pointless looking elsewhere.
Martin
Old Oct 18, 2012 | 04:46 PM
Bungle's Avatar
Bungle
Dampness in the car will cause the windows to mist up badly and quickly have a feel at the carpets in the footwells front and back and check rear light seals etc and the trim that surrounds the boot lock also what engine is actually in it? I may have missed that I'm knackered
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
