Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
interior lights
Old Oct 13, 2012 | 09:09 PM
Default interior lights
Can some one take a pic of there interior lights.Ive bought a rear light to go on the back of the car.Its the same type as the focus ghia and the ST 170 has.Also can anyone measure from the back of the headlining to where the light is and from where the doors are to the light.
Its a 5door focus hatchback.
Thanks.
Old Oct 13, 2012 | 10:20 PM
TheSupremeAuthority's Avatar
TheSupremeAuthority
I've but some lights in the rear of mine but the are the vanity lights from the st170
Old Oct 14, 2012 | 03:38 PM
They look well.So can you do the measurments for me and take a pic of the rear light for me.
Old Oct 14, 2012 | 08:08 PM
yunii's Avatar
yunii
Wink
before i had ghia one.
then this
now this: st3 submarine lights in front & centre roof
yunii
Old Oct 14, 2012 | 11:03 PM
TheSupremeAuthority
The way yunni has done it is easier, but i'll show you my way as well.
about 1m of 2 core wire on each side then connected them into the main light (the orange/blue and black/blue connections)
I'll have to get some proper measurements up tomorrow (iirc the lights are about the size of a debit car)
However, you do need to cut away at the metal behind as they simply don't fit otherwise. (one of the sides is more fiddly/require more metal to be cut to accommodate the connector/plug going to the light)
Old Oct 15, 2012 | 04:16 AM
yunii's Avatar
yunii
Btw , I didn't have lights in centre or vanity lights behind visors. Yunii
Old Oct 15, 2012 | 04:26 AM
Cheers people.Does the orginal ghia rear interior light have a cream surround like the front interior light has.
I still need measurements to people.
Thanks for the pics.
Old Oct 15, 2012 | 05:50 PM
yunii's Avatar
yunii
i also fitted vanity lights under the visor
Old Oct 15, 2012 | 08:58 PM
I was gonna do that too.
Can you answer my post above by any chance...please.
Old Oct 16, 2012 | 03:08 PM
yunii's Avatar
yunii
what i did was aligned it with the front one for centre ,then measured from grab handle to grab handle & split the distance in half,then make a mark for the exact centre. yunii
Old Oct 17, 2012 | 11:22 AM
Yeh i thought of that.Just been lazy and wanted someone to give me messurments lol.Did it take you long to do.Should there be a metal ring that goes in first then the light clips into this or does it not matter.
I was in my dads mondeo jag last night and noticed his rear interior light was the same as the focus light.
Old Oct 18, 2012 | 07:03 PM
yunii's Avatar
yunii
yes their should be a oval metal ring with tabs that bend up over the lining pressed against tight to it, i used the ring to mark out the cut out shape to cut out,cut the inner of the ring,their same on most earlier fords. yunii
Old Oct 18, 2012 | 07:09 PM
yunii's Avatar
yunii
i have complete set of vanity/visor lights spare pm me if interested. yunii
Old Oct 19, 2012 | 11:17 AM
I havent got the ring but i will just cut the hole a bit smaller so that when i fit the light it wont fall out lol.
155lee
Oct 24, 2015 11:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
