Can I do away with my shogun oil cooler?
Oct 12, 2012 | 09:28 PM
As above my oil cooler on my 2.5 td shogun sport is fucked and I can't find one on the net to replace it just now so could I just join up the hoses?
Oct 12, 2012 | 09:45 PM
no reason why you cant, but it will run hotter lol
Oct 12, 2012 | 09:51 PM
oil cooler for what?
engine, pas, transmission?
is it water cooled or air cooled type?
pic?
Oct 12, 2012 | 09:52 PM
they are normally fitted for countrys with a hotter climate, ive removed a lot off various vehicles and never noticed a problem yet
Oct 12, 2012 | 09:54 PM
Engine oil cooler yes transmission oil cooler no
Oct 12, 2012 | 09:55 PM
Quote:
Originally Posted by
Cossie Sean
pic?
Im guessing engine oil cooler! Sits right at the front of the car next to the fan! I'm guessing it's air cooled being at the front?
bollocks,
they are for high load usage
whats an oil cooler gonna do in 20degree heat difference? (on any component!)
Oct 12, 2012 | 09:56 PM
What colour is the oil coming out of it jet black or red / brown
Oct 12, 2012 | 09:57 PM
could be for anything being at the front matey, follow the pipework and see where it goes
most likely PAS or transmission if its a spastimatic
Oct 12, 2012 | 09:58 PM
Cossie Sean
bollocks,
Are you a transmission specialist ?
Oct 12, 2012 | 09:59 PM
flannigan
Jet black mate
Oct 12, 2012 | 10:00 PM
Cossie Sean
It's a manual and the oil is pure black engine oil!
Oct 12, 2012 | 10:01 PM
Engine oil bypass it and you will never have a problem mate unless you are planning on doing trackdays in it pmsl
Oct 12, 2012 | 10:03 PM
due an oil change then lol
7l of oil in one of those bad boys iirc!
just remove it mate, should be fine!
Oct 12, 2012 | 10:04 PM
Fudgey
The cooler is tiny!
Oct 12, 2012 | 10:05 PM
flannigan
Lol cheers mate
Oct 12, 2012 | 10:06 PM
i meant the total oil volume for the engine, not just the cooler lol
Oct 12, 2012 | 10:07 PM
flannigan
thermal dynamics and stress
not transmission specialist but spent a lot of time understanding the above subject
there wouldnt be an oil cooler in place if it wasnt needed as some point
towing a trailer or carrying more than 3 passengers puts huge load on internal combustion engines, transmissions and differentials, agreed?
Oct 12, 2012 | 10:11 PM
Oct 12, 2012 | 10:14 PM
http://www.ebay.co.uk/sch/i.html?_sa...+cooler&_frs=1
none for sale
Ł20 should see you right, not worth the risk IMO
i have bypassed these type before but just as a "get by"
the PAS/Auto transmission universal type would also work very well, something is better than nothing matey
Oct 12, 2012 | 10:16 PM
im not being arsey here, honestly!
just dont want to see anything put under un-needed stress causing premature failure for the sake of a Ł20 oil cooler
Sean.
Oct 12, 2012 | 10:29 PM
Cossie Sean
Sean.
I've looked on eBay and they don't have my model of oil cooler! If it was 200 quid I wouldn't be bothered lol but I'm not giving mitsi 500 quid for a small oil cooler lol it's a total joke
Oct 12, 2012 | 10:40 PM
other models will "fit"
the 2 pipes will just be push on pipes with sprung jubilee clips yes?
just buy a universal cooler and fit that,
like this:
http://www.ebay.co.uk/itm/UNIVERSAL-...item3367aff309
Failing that, send me a pic of yours and i will help better
Oct 19, 2012 | 08:26 PM
Finally got one today! Thanks for the advice
Brickhouse
14
Oct 3, 2015 07:28 PM
