Struggling to find Pistons
Hi there,
Im trying to find some pistons for my 2.1 pinto. Its 93mm 2.25
The only place ive found is Burton i was wondering if anyone else knows anywhere at all?
CheeRS
CheeRS
you can but with offset drilled 1.6d rods.
Apollo i will have a look for you see if i can dredge anything up.
failing that im sure accralite and JE do these,
what is your pin dimensions?
Sean.
Sean.
Thanks for the replies, ideally id rather not go down the Cologne route as quite a bit of machining is needed from what ive heard. I currently dont have any Connecting rods so im after those aswell. Its a standard crank. Bore is 93mm
I used wossner's in mine from matt lewis, here's a pic of them, im sure there 93+mm, fitted straight on the cossie rods
http://www.turbosport.co.uk/showthre...oday&highlight=
