Where do i wire the amp?!
Old Oct 10, 2012 | 09:05 PM
mrmkd's Avatar
mrmkd
newbie
Cool Where do i wire the amp?!
hi guys i have a 2004 ford focus c max
wiring up a sub and amp to it...have done everything, but have no idea how to feed the wire through the firewall to connect to the battery
if you have experience in this please reply
Old Oct 10, 2012 | 09:10 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
possibly worth taking the wipers off and the scuttle panel to see if there is a gromet under there 10 mins well spent
Old Oct 10, 2012 | 09:11 PM
mrmkd's Avatar
mrmkd
newbie
thanks that seems a good idea...
is it easily removable?
Old Oct 10, 2012 | 09:15 PM
daviddunlop83's Avatar
daviddunlop83
I know on my focus they drilled a hole near the passenger footwell and used a firewall grommet tho it was for zero gauge wire.
Old Oct 10, 2012 | 09:19 PM
mrmkd's Avatar
mrmkd
newbie
yeah drilling is also an option, the wire is heavily insulated so shouldn't be a problem...just dont know where exactly to drill lol
Old Oct 11, 2012 | 08:43 AM
Twizz's Avatar
Twizz
Out of many, we are one.
On the MK1 focus's, you used to be able to go towards the end of the head lamp, then around the washer bottle, user the flap at the bottom of the wing, through the plastic gromit (near the hinges there's a plastic unused gromit) and your in.
Is there anything similar?
Old Oct 11, 2012 | 06:21 PM
costina's Avatar
costina
Live long and prosper!!
You must use a grommet in the hole you drill otherwise it will end in a very big melted mess and could cause serious injury.
Do it once do it right
Old Oct 11, 2012 | 06:25 PM
daviddunlop83
I had a grommet like this
http://www.ebay.co.uk/itm/Stinger-Wi...-/400213719265
Old Oct 11, 2012 | 06:29 PM
costina's Avatar
costina
Originally Posted by daviddunlop83
Thats fine even a cheap rubber job will be fine. it wont take long for the metal edge to eat thru insulation
Old Oct 11, 2012 | 09:06 PM
mrmkd's Avatar
mrmkd
newbie
thanks for the replies guys, turns out i didn't even have to drill a hole, someone i know managed to fit it through a gap in the left wing panel!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
